Old 07-18-2018, 08:27 PM   #1
Outdoor kitchen plumbing question
365saqb Sierra outside kitchen plumbing.
Advise please. Anyone had to remove the hot or cold water soft hoses (have to flex) , that are crimped on at the “T” for low point drain and the sink. What is the BEST way to remove a hose and replace it? One of mine sprung a leak. Thank God for the shut offs in bathroom. Flooded the underbelly. . We r camping. Thinking you have to just pry the crimp off and use small radiator clamps to put back on. Any advise is much appreciated. Thanks.
quick83 is offline   Reply With Quote
Old 07-19-2018, 06:42 AM   #2
SeaDog's Avatar
Its difficult to say without seeing the fitting, but if its the Oetiker type you can use a small flat blade screwdriver to pry the crimp open with a twisting motion (don't pry against the pipe) replacement with a standard screw drive hose clamp will work in most cases. JMHO
Retired Navy
2016 Flagstaff 26 FKWS
Old 07-19-2018, 07:53 AM   #3
Thanks much.
door, plumbing
