Old 11-11-2015, 12:32 AM   #11
SKnight's Avatar
Originally Posted by Jscribner View Post
SKnight
It sounds like you have a frame problem, the tank falling down and the bend by the spring. Our camper has broken cross members over the axles and has a bend behind the street side rear spring hanger. The braces that hold the tanks up where starting to come loose. I would suggest taking a closer look.
Oh I'm not dismissing it. They are.
The tank was "My" fault. I used the regulator, hooked the hose up and started filling the tank as I continued packing. Apparently the hose can outflow the vent, because a few minutes later I heard the frame for the fresh tank give out. It ended up being pressurized because water couldn't get out fast enough. So I built a valve that allows me to cut the flow rate. It takes forever to fill now, but at least that won't happen again.
I have no idea how the primary frame bent. The right rear spring mount is bent outwards at about a 20* angle. In my ownership it's not seen a hard hit, it's not run over anything. The rail is straight, it's like something hit it from the side kicking the perch out. It's got the spring pack misaligned, but they say it's not detrimental. Right. It's because the tires are wearing nicely, that's their only defense of their action.
I'm going to write out something basically stating it won't be an issue and that they assure and assume it will never cause a problem. The service and general manager will sign it before I leave.
But odds are I'll just fix that myself too. Framework isn't hard, just a matter of pressure and heat.
Old 11-11-2015, 04:30 AM   #12
If I was a betting man I'd bet your frame was made by LCI. Its easy to tell...just look at any weld and if it looks like a 1st grader welded it thats LCI. Most likely there will also be a label on it somewhere.They start out welders @ $12 hr I have heard, no experience required. The frames they make for small trailers are borderline at best, 5ers I can only Imagine. If so you probably could make it much better with little work if you know how to weld.
I'd get that document signed by the owner. You never know how long the GM or SM will be there, and are they even legally able to sign such a document? Id also want a witness or to have it notarized. They will probably balk at signing that regardless. Good luck
Mr Havercamp is offline   Reply With Quote
Old 11-11-2015, 11:55 AM   #13
Originally Posted by Camper John View Post
Our 5r is now 6 months old. We had it in the shop for the first 2 months getting a slide repaired. Our latest issue is with the drop patio deck. It has become spongy very hard to assemble. We called our selling dealer and he said better get FR involved. I have now waited 2 months but nothing from Forest River and the dealer has stopped communicating. This is starting to get scary. First the slide would not retract and that repair took two months and now everybody we talk to says FR has a problem with these and nobody is getting answers. HELP!
What's "Spongy" on your deck, could you elaborate on this? Mine is solid and have had no issues with it. Only thing to assemble is to raise the rails which is a matter of pulling four pins, raising the railing and reinstalling the pins. Just curious what the issue is.
Sierra360PDEK is offline   Reply With Quote
Old 11-18-2015, 03:55 PM   #14
Camper John's Avatar
I have been away from the Forums for a few days and need to reply to some questions about my problems. First off, the spongy feel is just that it feels like we are walking on a stiff sponge. Because the floor is spongy #2 the assembly of the side fences is very hard to do and get the rear gate to latch properly. I have emailed Mr. Johnson at Sierra warranty several times with no response. His voice mail is continuously unanswered also. It took me over two months to resolve the slide issue with an authorized repair facility and had to resolve a lien they placed on the coach because the bill didn't get paid. I'm not having a warm & fuzzy about our purchase and because these issues are major repairs not little stuff our concerns are growing.
Camper John is offline   Reply With Quote
Old 11-20-2015, 03:01 PM   #15
On your hand rail issue, you can drill out additional holes on the feet to level. It's very easy to do and will allow your gate to close properly. The spongy feel may be the large springs pulling the deck up and then the cables catching as weight is added. Ours does this and it does feel strange at first.
Ours is has had issues, fresh water tank fell out, water in nose cone and a cracked island counter top. Our dealer has been great and fixed everything under warranty.
Old 11-20-2015, 03:17 PM   #16
The spongy deck is a surface issue is not the cable tensioning. I have no desire to drill additional holes as the gate closed and latched just fine until the deck issues began. But thanks for your comments.
Old 02-12-2016, 12:58 PM   #17
The problem was a misalignment of the slide guides on the kitchen super slide. The repair facility said it was the worst case of engineering they had ever seen. They worked with Lippert to re-engineer the entire slide mechanism. I was very lucky that I had a talented repair shop. BUT! They won't work on the PDEK because they said it was a materials issue and nobody had changed the materials they use. OUCH!!
Old 06-14-2016, 07:40 PM   #18
Retired Retail/Importer
I just picked up our new 360PDEK last week and today the Dometic A/C is not working the thermostat says E-1 which is an error but I can't get it to reset....it shows a zone 4 when we only have 2 zones...
pledbetter is offline   Reply With Quote
Old 06-14-2016, 07:41 PM   #19
Dometic A/C
any help on a Dometic A/C thermostat error showing E1?
