Old 03-23-2018, 07:24 PM   #1
Relay switch
Hello everyone, anyone know where the relay switch is on a Forest River Sierra 5th wheel? My slides keep tripping the relay when I try to put them out. Thanks.
Mcnet22 is offline   Reply With Quote
Old 03-23-2018, 08:43 PM   #2
Hydraulic slides?
If so I believe it will be located in the curb side front compartment. That's where all of my wiring to the pump is located.
whitewinghunter is offline   Reply With Quote
Old 03-23-2018, 08:50 PM   #3
They are hydraulic, I will check that, thanks
Old 03-25-2018, 08:40 AM   #4
Had the same problem with mine, I have hydraulic slides. The breaker should be an automatic reset type and would be close to the battery as possible. Could be 3 things wrong with. 1) bad pump motor drawing to many amps 2) bad breaker, tripping before itís supposed to 3) batteries are bad/to low on power. Mine was a bad breaker, got a new one for $8 and good to go. Start with that, itís the cheapest. Also does it trip only on battery power or does trip also on shore power?
Ross.Pajich is offline   Reply With Quote
Old 03-25-2018, 09:55 AM   #5
It trips both on battery, and when plugged in. I tested the battery, it's good. Is the breaker in the breaker box or by the battery? Thanks
Old 03-27-2018, 06:02 AM   #6
Sorry for the long delay, didn’t realize you replied. Breaker would be close to battery. Mine is located in the front left compartment right above battery. Follow the red 4ga wires to locate. Do you know what a automatic reset automotive breaker looks like? My camper is still in storage, so can’t send pictures for a week or two.
Old 03-27-2018, 07:22 AM   #7
AquaMan's Avatar
The breaker is most likely mounted to the sidewall on a bus bar in front compartment under pinbox. I, under direction from FR, installed a heavier breaker and solved my issue. I believe I went to a 40amp breaker, but can't be certain.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 03-27-2018, 07:43 AM   #8
Thanks for the help, much appreciated. Ross, I have never seen one prior to this camper. My old TT had the same issue, but the breaker was mounted right on the bumper and was very small.
switch
