Replacement dinett window
I bought a 2008 Sierra 301 bhd with a damaged dinette window. This is the large dinette window and it must be replaced. Not sure where to find the replacement for this window and also will require additional work to install since appears that wall surrounding the window also incurred damage both inside and out when the window was initially damaged. I purchased the trailer this way. Any help in locating the window and possible advice on who or where I can get work done on repairs would be appreciated. I am not sure if I can do the repair work since I have been told that interior wall needs to be cut back to a stud to do the job correctly and exterior appears that fiberglass finish will require work further out than just the window frame.
