Old 04-04-2017, 01:06 PM   #1
PulBein's Avatar
RV power converter
So I have looked just about everywhere I can for my 2014 Sierra select 30IOK's power converter so I can attempt to replace it myself. Any suggestions? Places I might have over looked? Any help would be much appreciated. Thanks!
PulBein is offline   Reply With Quote
Old 04-04-2017, 01:09 PM   #2
Kenny kustom's Avatar
in the basement. Behind the back wall.
Old 04-04-2017, 01:12 PM   #3
It is usually part of your power distribution center. (breakers and fuses)
You typically have to remove to install the converter portion.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 04-04-2017, 01:13 PM   #4
His will likely be separate. mounted on the floor, behind the back wall.
Old 04-04-2017, 01:15 PM   #5
Thanks Kenny, I tried to look up his model but couldn't find anything on the converter.
Old 04-04-2017, 01:21 PM   #6
PulBein's Avatar
Thanks Kenny, can you be a little more specific? As far as "Basement" and "backwall"
I apologize but I'm still learning this RV stuff and have been having trouble finding specific make/model info on my trailer.
Old 04-04-2017, 01:37 PM   #7
wmtire's Avatar
If it's not in the basement as Kenny described, you may can check to see if it's on the bottom or side of your RV's electrical distribution panel as 5picker pointed out.
If you see air louvers on the side or bottom cover of the distribution panel cover, this can be an indication the converter is there. You will have to remove the cover as shown in this pic (converter on bottom)
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 04-04-2017, 01:44 PM   #8
PulBein's Avatar
Awesome, thanks for the help everyone!
Old 04-04-2017, 01:54 PM   #9
Seems we should start a "seek and ye shall find" thread where everyone can post where the converter, BCC, water pump and icemaker shutoff valves are their specific model, pictures accepted. I am sure there are more...oh yes, the fuse for any convenience cigar lighter outlets, the park cable entrance and satellite if any. Maybe we should have a form.
This always happens before the season starts.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-04-2017, 02:01 PM   #10
PulBein's Avatar
That would be very useful and I could add all my findings to minimize the amount of times questions like mine are asked.
converter, power
