Old 09-06-2014, 08:40 AM   #1
Question SAQ365 Cable/SAT questions
SAQ365 2015 which I assume is the same as 2014. Here are my questions regarding cable/SAT. PLease correct any statement if I am incorrect.
1. I assume the cable ( NOT the SAT ) is run through out the RV via cable with splitters??
2. There are 3 SAT jacks in the docking station outside. I have no clue how they would be connected unless 1 SAT cable runs to each room??
3. Is there anyone who would know how to service cable connections if any issue arrived. Behind the docking station the cabling runs up in the floor via a 3 inch hole drilled. So from the docking station to that hole drilled in the only cable you can access is about 3 feet.
4. Any one have a cable/SAT diagram on how the unit was cabled??
Thanks all
mrwoodmin is offline   Reply With Quote
Old 09-06-2014, 09:15 AM   #2
golfmedik's Avatar
Some of the guys here have had to totally redo their cables in the past to get them to work correctly. Here is just one of the links http://www.forestriverforums.com/for...saq-42648.html
If you do an advanced search in both the Sandpiper and Sierra forums, you will find this is common.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 09-06-2014, 10:31 PM   #3
I have a 2014 and I think one is marked "sat main" which goes to the tv in the living room. I think there is one "labeled sat front" goes to the front bedroom.
The park cable labeled one is where you hook up the cable into and you will have to change the tv from over the air to cable and do a search.
Also the park cable goes to the coax outlets in the trailer. You will need to turn off the signal booster.
Cajun Moon is offline   Reply With Quote
Old 09-09-2014, 06:52 PM   #4
Thanks for the replys!!
