Old 07-10-2012, 08:52 AM   #1
second battery thoughts?
Anyone put a second battery into their unit? Im thinking about adding a second to my 365SAQ but trying to decide if its worth it.
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
Beausdog is offline   Reply With Quote
Old 07-10-2012, 09:10 AM   #2
AquaMan's Avatar
Been thinking the same thing. The parasitic drain on the 365saq is fairly heavy, at least seems so to me. If I do, I believe I'm going to go with 2 6 volt batteries. Last much longer, and I can get for same price or cheaper than good RV batteries. I usually disconnect my battery, but if I forget, it's dead within a week or so. I do know, the batteries should be matched, brand, type, age, etc.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 07-10-2012, 09:15 AM   #3
Herk7769's Avatar
If you stay in full hook ups most always it is not worth it.
If you boondock even a little you will find it a required upgrade.
The standard dual purpose battery has about 70-80 amp hours of capacity and will last with typical usage in warm weather and minimal lighting about 2 days till dead. Anything more than that will require a generator.
If you boondock in cool weather where the furnace is used, overnight is about all you will hope to get out of a fully charged battery.
If you add an inverter to use any 120 VAC appliances on battery, two (or more) batteries will be required. These are photos of my modification to the front bay of my 5th wheel in order to create a power compartment.
ID:	16320   Click image for larger version
ID:	16321   Click image for larger version
ID:	16322   Click image for larger version
ID:	16323   Click image for larger version
Name:	6 June 2009 017.jpg
HAM CALLSIGN - KC3FFW
Old 07-10-2012, 09:16 AM   #4
I may pull the trigger today, just feeling like it should have a couple batteries in it....also looking at generators as well
Old 07-10-2012, 09:17 AM   #5
miatared's Avatar
It all depends of what you need. If you will be doing some dry-camping (no electricity) or boon-docking (in the boonies with nothing at all), then a 2nd battery would help.
It's all to do with Amp-Hours.
A typical 12V dealer installed battery will give you 75 AH. (marine deep cycle type), so 2 of the same would give you 150 AH for example, enough to run a 5A motor for 30 hours. (150 / 5 = 30). One such battery would give you 15 hours only.
I have elected to go with 2 - 6V Golf Cart batteries - wired in series to give me 12V, from Costco ($80 each) and that provides for 220 AH. These batteries - according to many - are better suited for RVs and deep discharges. I have switched all my interior light bulbs to LEDs to reduce power consumption. The heater fan is what consumes most power.
I am very happy I made the switch.
Denis & Diane
* Happy Campers *
miatared is offline   Reply With Quote
Old 07-10-2012, 09:20 AM   #6
Did you do that yourself or have it done professionally? Looks amazing and what is the red thing below the inverter on the wall just above the batteries (looks like a switch of some sort)
Old 07-10-2012, 09:23 AM   #7
I like the LED thoughts, where did you get the bulbs? same original housing or did you have to change the whole fixture? Mine has some LEDs but I would love to have more inside as they are brighter and draw less power. I bought two more LED TV's for my rig and they all work wonderful without pulling a lot of power
Old 07-10-2012, 09:29 AM   #8
Herk7769's Avatar
I did that "mod" myself 7 days after taking delivery. Except for this year, we typically "boondock" about half the time. Last year we boondocked over 30 days.
The red thing is a Marine dual battery switch. That allows me to switch out a dead battery if it should ever fail due to plate damage. That is why I will always be using 12 volt batteries. Batteries can fail suddenly if a plate cracks due to impact (like a chuck hole in the road) and it shorts out internally. If this happens with a 6 volt battery you are done with no recovery. With 2 12 volt batteries, a bad one can be switched out and you can "keep on camping" with reduced capacity until you can have a new one (or two) shipped in.
If you have any other questions about the mod let me know.
Old 07-10-2012, 09:31 AM   #9
Herk7769's Avatar
MANY threads here on LED replacements.
LED 12 volt lighting: Long term results
Old 07-10-2012, 09:35 AM   #10
Thanks again The DW is sooooooo not gonna be happy when I get done with my shopping trip
battery
