Old 03-22-2018, 04:12 PM   #1
Calsiera's Avatar
Self Closing Bedroom Drawer
Hi all,
I have a slight problem. I cannot get my bedroom dresser drawer to close. It goes in up to a couple inches.
There has got to be a catch or something there, right? I have had no problems with it until earlier today. I did pull the drawer out probably all the way and now I can't get it to close. I have tried to find a catch or something to no avail.
Does anybody know how to close it? Any ideas are greatly appreciated!
Thanks!
Calsiera
2017 Sierra 371 REHB
43 ft. Fifth Wheel
Calsiera is offline   Reply With Quote
Old 03-22-2018, 04:27 PM   #2
Originally Posted by Calsiera View Post
Hi all,
Thanks!
It sounds like when you opened it all the way, it got derailed off the drawer glides. Do you notice it sitting askew in the opening? Try to get it back on track.
Either that or something is stuck behind it.
kfergiez is offline   Reply With Quote
Old 03-22-2018, 04:36 PM   #3
Kanadian Kamper
kenandterry's Avatar
Are you able to release the side rails and remove the drawer completely?
Look carefully, and you should see some small arms (sometimes plastic) that are spring release from a clip on the metal side rails of the drawer itself....which all has to align with the rails mounted inside the cavity of the drawer.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 03-22-2018, 04:39 PM   #4
Chief T's Avatar
That's what I was thinking. There may be like a clip/lever on the track that needs to be opened. Recently put a file cabinet together with this set-up.
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2021: 19
Days camped 2020: 18
Days camped 2019: 17
Chief T is offline   Reply With Quote
Old 03-22-2018, 04:56 PM   #5
Kanadian Kamper
Pix of release tab for drawer
Ken and Terry
Old 03-22-2018, 04:59 PM   #6
Kanadian Kamper
Once more.....
ID:	165882   Click image for larger version
Ken and Terry
Old 03-22-2018, 05:11 PM   #7
Just as confused as you
Scrapper's Avatar
On the opposite side you need to lift on the small plastic lever. At least on my drawers you do.
Richard & Jill
Old 03-22-2018, 06:44 PM   #8
Calsiera's Avatar
I have tried to push it down, I have tried to push it up. I can only hold onto it until it goes into the metal part I can't get into. Here is what it looks like..
Well, I was going to show you a picture, but, I guess I don't know how to upload one here.
Calsiera
43 ft. Fifth Wheel
Old 03-22-2018, 06:46 PM   #9
Calsiera's Avatar
Yes, it is sitting askew. There is nothing behind it. Trying to get it back on track.
Calsiera
43 ft. Fifth Wheel
Old 03-22-2018, 07:20 PM   #10
Calsiera's Avatar
kenandterry...
I have tried to post pictures but don't know how to upload them.
Calsiera
43 ft. Fifth Wheel
Old 03-22-2018, 07:34 PM   #11
herbike's Avatar
Our glides were mounted too far apart. Had to space them with a small piece of luan. They were hard to pull to start with and I took them out then couldn't get them back in. Took it back to the dealer and they shimmed them for me.
We love camping in our Shockwave!
2016 t28FQDX Shockwave,
New Provider tires 10/31/18 ,
2021 Chev LT 3500
2020 Polaris RZR 900 Fox Edition
herbike is offline   Reply With Quote
Old 03-22-2018, 07:36 PM   #12
CampingGator's Avatar
You have to hit the go advanced tab. Scroll down to the upload pictures section. You can upload up to five pictures. When you have them all there, then hit the upload button and then you scroll to the bottom and hit close this window. I hope I didn’t miss a step, but I think that is how you do it.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
CampingGator is offline   Reply With Quote
Old 03-22-2018, 08:52 PM   #13
Calsiera's Avatar
Well, I tried to upload pictures but for some reason it would freeze when I hit Upload. Anyway, we did take the drawer totally out, found a metal clip that needed to be reset and now it is closed....never to open again. (only kidding)
Thank you all for your help! I always know when something goes wrong someone here has the answer.
Calsiera
43 ft. Fifth Wheel
Old 03-22-2018, 09:09 PM   #14
RSchleder's Avatar
The small black plastic clips (long slender flexible spring type clips) need to be released and the drawer squared up front to back on both sides of the drawer. On one side the plastic clip will need to be pulled up away from the metal rail and on the other side the clip be need to pushed down as it will be mounted on the bracket below the metal rail.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 03-23-2018, 03:43 PM   #15
BobHanke's Avatar
If you have the kind of slides that kenandterry showed in their pictures, it is most likely that the lever goes up on one side and down on the other. Having something blocking a drawer from behind specially the lower one(s) is a bit common.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
BobHanke is offline   Reply With Quote
Old 03-23-2018, 04:54 PM   #16
Bene Gesserit Rule
Murbella7's Avatar
There may also be something behind the drawer preventing it sliding all the way in. The plastic clips are opposites, one works up, the down. A tip when putting them back in... pull out one rail, slide the drawer on then do the other. When you push the drawer all the way in the clips should engage automatically.
Murbella7 is offline   Reply With Quote
Old 03-23-2018, 05:00 PM   #17
BessieHunter's Avatar
If it is self closing, probably the self closing mechanism broke at the back of one of the slides and is stopping that slide to go all the way in. Had that happen on one of our self closing drawers.
BessieHunter is offline   Reply With Quote
Old 03-23-2018, 05:25 PM   #18
Scrapper's Avatar
It takes time for the pictures to upload to FRF. Depending on the speed of the connection, the size of the file, and how your uploading, ie cell service, satellite or cable, the time can be considerable. I'm on satellite and have seen upload time as long as 5 minutes. After you click on Upload it looks as though nothing is happening but when it's done the file name will appear in a section lower down.
Richard & Jill
bed, roo
