Old 10-21-2014, 11:11 AM   #1
Sierra 355QBQ
Winterize question. I have a 2010 355QBQ. I have never done the winterize on it. I have always taken it to an RV dealer. This year however, the price had gone up to $107. Seems pretty high. Anyone out there with this unit done the winterizing on their own that can instruct me on how to do it?
OKI Marine is offline   Reply With Quote
Old 10-21-2014, 11:18 AM   #2
TURBS's Avatar
Do you have the winterize option?
BTW I sent you a couple pm's on your tailgater.
Turbs
Old 10-21-2014, 11:23 AM   #3
TURBS's Avatar
First drain low point drains.
Drain water heater.
Bypass water heater.
Remove interior water filter and place canister back on.
If you have the winterize option then turn that on to suck the antifreeze out of the jugs "you'll need 4 gallon"
Run furthest tap first hot and cold till good and pink, then work your way closest to where water station is.
Dump a cup or two of antifreeze in each drain.
Don't forget to put some on top of the toilet seal.
Also don't forget outside shower if applicable.
Once you've done it a few times 30 minutes is all it should take.
Turbs
Old 10-23-2014, 08:23 PM   #4
golfmedik's Avatar
Just like Turbs said, but also remember the Spray Ports if you haven them, along with outside kitchen and washer and dryer preps. Drain all low points. Front, rear and your fresh water tank. You should have a hose that will pull out from the docking station. Look down under the water filter and you will see a valve. Turn it to off, take cap off of hose and put it into antifreeze. Turn on water pump and pump the pink stuff through all lines.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 11-01-2014, 02:45 PM   #5
Computer Nerd's Avatar
One thing to add is I dump more anti-freeze in my tanks than he ecified, otherwise, that's it.
Computer Nerd is offline   Reply With Quote
Old 11-01-2014, 11:51 PM   #6
SKnight's Avatar
In the past I used five gallons or so. It usually took about 3.5 for the pressure side of the system, the half gallon I'd pour down the traps just to make sure, a gallon into the black tank to mix with what was already there, and I'd leave a couple of cups worth on the flush valve to keep it moist.
I imagine the 5er will take about the same, I'll get an extra gallon because I have a water filter and washer lines in the bedroom then adjust next year.
sierra
