Old 08-06-2013, 07:47 PM   #1
fishgolf365's Avatar
Sierra 365SAQ
Does anyone know if the vent in the rear half bath is wired so an exhaust fan of some type can be installed? Thanks.......
fishgolf365 is offline   Reply With Quote
Old 08-06-2013, 08:19 PM   #2
golfmedik's Avatar
I do not believe it is. Some order a fan there from the factory. With a fish tape and tying into the switch for 12 volt, I don't think it would be that big of a problem. I know some have done it, just can't remember who they are.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 08-07-2013, 03:48 AM   #3
OK. Thanks for the reply. I will take a look at it.
Old 08-08-2013, 04:18 PM   #4
ehorn's Avatar
They aren't wired from factory unless ordered that way. We got them to out fantastic fans in all the vents. Bunk room, half bath, living area, and main bath. These keep the trailer very comfortable without running either of the a/c's
2014 Sierra 365 SAQ
2014 F350 CC DRW lariat ultimate kodiak brown, 65 gallon titan fuel tank, bak flip box cover, many mods to come.
ehorn is offline   Reply With Quote
Old 08-08-2013, 04:25 PM   #5
Thanks ehorn. I have a fantastic fan in the front bath but nowhere else. Question--In the bunkhouse and rear bath are the fans wired to the wall switch? It seems it would work that way since the fan will not come on until it is opened. I have put a different opening knob on them so they can be opened standing on the floor.
Old 08-08-2013, 04:27 PM   #6
ehorn's Avatar
Mine all have the electric lid which opens and closes by pushing up or down, then there is a dial you turn to select the speed you want the fan to run at. Very nice since there is no way I can reach the vents to open them.
2014 Sierra 365 SAQ
Old 08-08-2013, 05:00 PM   #7
OK, thanks. I will check around for my after manufacture options.
