I have the treehouse model, but believe it is the same setup. I have the 2 sat and 1 cable connection on outside of camper. What I have found is this: The top sat connection feeds the master bedroom and the bottom sat connection feeds the living room. I also have coax ports in loft, back room, and basement but they are only fed thru the cable port. I have been unable to get sat to work on any of them. Also the tv in living room has two coax cables, grey(sat) and white(cable). If I was hooked to cable in the park I would have to hook the white cable up in LR and if I was hooked to sat then I have to hook grey cable up. I installed a switchbox so I could just switch back and forth without have to remove the tv. If I am hooked to cable, it feeds all tv's. If I am hooked to sat, I only get it on LR or Master bedroom. I run a duo reciever, so I have a sat ine in both sat ports on camper and I have the duo receiver in the bedroom and that works the bedroom and LR tv independently. If I choose to watch tv outside, I just hookup the HDMI cable i have fed from the bedroom to the basement thru a water pipe hole. I leave that cable there so aloo I have to do is move tv out and plug it in. I was really frustrated when I bought my rig 3 years ago because I could not get any answer on the setup. I tried the dealer, salesmen, folks at camper shows, and a factory rep, and still nothing. It was alot of trial and error.
Jeff n Lori
2011 35 Loft "Treehouse"
2011 Dodge 3500 Crewcab "Cummins"
