Originally Posted by Scooterb
Maineiac, we were in our RV this past weekend. I went into the storage belly and pulled out the receptable. I put a flashlight in the outlet hole and peered over at the wiring into and out of the outside outlet. The backside of the outside outlet had a line running from it to the storage compartment outlet. I'm guessing this same line is disconnected on your RV.
As for the kitchen outlets, I saw that the panels between the underbelly storage and compartment with the plumbing and wiring, are easily removed by removing the fasteners. I was tied up this past weekend, although I plan on removing a panel to access the electrical wiring and finding the source of the problem. I have non-contact circuit tracer that will make short work of finding hot wires and dead wires.
Hope this helps.
Did you speak with the FR production manager?
you are right - the line from the outside outlet to the storage compartment outlet was disconnected and just laying loose in that space under the stairs. I re-connected it and now that outlet is fine.
in the kitchen the 3 are still dead. the one on the end of the counter and on left side of the wall under the cabinets have just a single line in. the one on the right side of the cabinet wall has a line in and 2 lines out (I'm assuming to feed the other 2 dead outlets)
so now my question is where does the line that feeds the outlet on the right side of the cabinet wall come from? if we can trace that back we might be able to find where it is disconnected
