Old 04-12-2016, 08:02 PM   #21
Thanks guys, I had a problem this past weekend with the leveling system. Did not know how to manually raise the legs. Turned out to be the fuse. I've since located instructions on manually performing this procedure, but I was curious about the hand crank.
Mels49 is offline   Reply With Quote
Old 04-12-2016, 08:12 PM   #22
I've also had several past problems with the landing gear from blown fuses. I took it in for service and the put an automatic relay switch in place of the in line fuse. No more blown fuses. The relay will automatically reset itselt in 3 seconds and power it back up.
Wumba is offline   Reply With Quote
Old 04-14-2016, 06:11 PM   #23
Let me know how to hook up satellite! We love ours!
CherylP is offline   Reply With Quote
Old 04-14-2016, 06:25 PM   #24
Snopusher - I've inquired about this issue in a previous thread, and never really got an answer.
Look in your battery compartment. Are there two cables, black & red, that are labeled "inverter"? And are the cables hooked up to anything, or are they just tied out of the way?
Mine are tied up, out of the way, with the red cable going to a 100a breaker, just above the batteries.
I do have an inverter, and everything seems to be running fine. I've attached a few pics. Let me know what you find. Thanks.
Name:	ImageUploadedByForest River Forums1460676283.896509.jpg
ID:	104924Click image for larger version
Name:	ImageUploadedByForest River Forums1460676298.962161.jpg
377FLIK
kasedian is offline   Reply With Quote
Old 04-14-2016, 06:27 PM   #25
I checked the red cable for power, and I do have 12v. It is taped up. I'm wondering if these cables go to another inverter that can be installed. Stumped.
377FLIK
Old 04-17-2016, 07:01 AM   #26
Name:	ImageUploadedByForest River Forums1460894484.739689.jpg
Mine is attached see photo.
Snopusher is offline   Reply With Quote
Old 04-17-2016, 09:18 AM   #27
Thank you. I see you have the single battery. I'm curious if it is the same set- up as the dual batteries.
377FLIK
Old 04-17-2016, 10:53 AM   #28
We have no satellite hook up that we can find, to the TV in living room.
Old 04-17-2016, 11:26 AM   #29
Cheryl - Mine is hooked up to the "Satellite Main" connection. It is for the tv in the living room. I assume the "Front" input, is the one in the kitchen. I hope this helps. Click image for larger version
Name:	ImageUploadedByForest River Forums1460910310.679636.jpg
377FLIK
Old 04-18-2016, 08:13 AM   #30
Thx, our panel inside has no satellite slot, just antenna and cable. That's what has us stumped!!
Old 04-18-2016, 09:20 AM   #31
Inside, up front in the living room, my Dish Network box is connected to the "cable" outlet. Hope this helps.
377FLIK
Old 04-18-2016, 02:58 PM   #32
Hey Cheryl. Inside, in the living room, the cable jack is going to the Dish Network box. The antenna is going to the T. Hope this helps.
Old 05-01-2016, 10:33 AM   #33
Unhappy sierra 2016 flik
Hello,
Help once again! Can someone tell me where the studs are in the bedroom slide? Our bed is pulling away from the wall and wallering out the screw holes.
ANY help would be appreciated!
Thank you,
Cheryl
sierra
