Old 10-01-2013, 09:28 AM   #11
golfmedik's Avatar
Originally Posted by 5erDriver View Post
Now that I look closer I guess it's permanent and looks like it tilts as the awning opens and lifts back up as it closes. Correct?
Yes. It pivots out when the awning comes out and catches the awning as it rolls up. You can get it through most camper dealers. There is another version out there that is non painted aluminum. I just liked the painted ones better. Also make sure when you attach it, use stainless screws or rivets so the bolts don't streak the side of the camper.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 10-01-2013, 09:38 AM   #12
5erDriver's Avatar
Cool. Thanks. Yes, I've since looked it up on PPL and a few others. Good deal!
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 10-02-2013, 09:20 AM   #13
TimeOutRV's Avatar
Our Coachmen Leprechaun has the Dometic power awning that is bowing and not rolling up correctly, BUT Also has the middle support. We've tried all the fixes I've found here in threads (pulling the awning straight on roller, putting a rivet in the ends to keep it straight, etc.) but it still rolls up slightly crooked (to the back of the RV), has wrinkles and bows ever so slightly.
Patrick & Stacey Burnett
Central Arkansas
2013 Coachmen Leprechaun 317SAF
1998 Seaward Fox Cat rigged trailerable sailboat
Our Lake Life Blog
TimeOutRV is offline   Reply With Quote
Old 10-14-2013, 05:54 PM   #14
5erDriver's Avatar
Originally Posted by golfmedik View Post
According to a couple of RV dealers around here, any awning over 16 feet need a center support to keep them from bowing. I had one on my 355QBQ and this is the one I put on my 3655SAQ.
Hi again. I bought the center support. Did you find it necessary to use the backing plate or did you just put it on anyway? The one I got is Dometic. Similar. Says you can use without the backing plate if it anchors well or use the backing plate if you feel the 2 lags haven't grabbed enough. Just curious. Will put on at the weekend. Thanks!
Old 10-14-2013, 07:45 PM   #15
golfmedik's Avatar
I used the backing plate as you can see here. It just looked like the support was a little more centered under the tube. It's not that thick but I put it on anyway.
