09-29-2013, 07:59 PM
Sierra awning issue
Does anyone with a 365SAQ Sierra have a bow in the awning roller. I has been noticing that when my awning is out it would sag on the middle and when it was rolled in it was wrinkled, not rolled smooth like it was when I bought the unit. I had it out today and noticed that when it is extended properly the roller bows in toward the camper causing the issue. My unit is a 2014 model. Thanks.
09-29-2013, 08:07 PM
09-29-2013, 08:11 PM
Thanks for the website. That is exactly what it looks like when rolled up. I will have to check with FR about it. RV is only 2 months old.......
09-29-2013, 08:16 PM
I think you would do better if you contact the awning MFG.
09-29-2013, 08:56 PM
OK. Good idea. I'll get the model number from it and give them a call. Can't hurt.
09-30-2013, 09:10 AM
It's pretty much going to be a fact of life with a 21' awning. Mine is the same way. They make awning supports, but I don't think they work with a power awning. Mine does roll up tight, (no gapping), but has the wrinkles in it.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
09-30-2013, 12:03 PM
I have the same issue. Although does roll tight is wrinkled and offset a bit in the roller. It has even slightly flexed both supports to the right when rolled up with the pressure. Functions fine and I think what is said is correct, with awnings this size they are going to sag in the middle somewhat.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
09-30-2013, 05:11 PM
According to a couple of RV dealers around here, any awning over 16 feet need a center support to keep them from bowing. I had one on my 355QBQ and this is the one I put on my 3655SAQ.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
10-01-2013, 07:15 AM
Nice and looks like a good idea. I'm assuming this is only put in place when the awning is closed? Looks like a keyhole style mounting. Other question is where did you buy? Thanks
10-01-2013, 07:17 AM
Now that I look closer I guess it's permanent and looks like it tilts as the awning opens and lifts back up as it closes. Correct?
10-01-2013, 09:28 AM
Yes. It pivots out when the awning comes out and catches the awning as it rolls up. You can get it through most camper dealers. There is another version out there that is non painted aluminum. I just liked the painted ones better. Also make sure when you attach it, use stainless screws or rivets so the bolts don't streak the side of the camper.
10-01-2013, 09:38 AM
Cool. Thanks. Yes, I've since looked it up on PPL and a few others. Good deal!
10-02-2013, 09:20 AM
Our Coachmen Leprechaun has the Dometic power awning that is bowing and not rolling up correctly, BUT Also has the middle support. We've tried all the fixes I've found here in threads (pulling the awning straight on roller, putting a rivet in the ends to keep it straight, etc.) but it still rolls up slightly crooked (to the back of the RV), has wrinkles and bows ever so slightly.
Patrick & Stacey Burnett
Central Arkansas
2013 Coachmen Leprechaun 317SAF
1998 Seaward Fox Cat rigged trailerable sailboat
Our Lake Life Blog
10-14-2013, 05:54 PM
Hi again. I bought the center support. Did you find it necessary to use the backing plate or did you just put it on anyway? The one I got is Dometic. Similar. Says you can use without the backing plate if it anchors well or use the backing plate if you feel the 2 lags haven't grabbed enough. Just curious. Will put on at the weekend. Thanks!
10-14-2013, 07:45 PM
I used the backing plate as you can see here. It just looked like the support was a little more centered under the tube. It's not that thick but I put it on anyway.
