Old 08-11-2017, 01:51 PM   #1
Slide leaking
I have 2016 Sierra 355re my bathroom slide have a leak in the rear side of it. I can`t tell if the water is coming in from the top or bottom, but it leaks at the bottom of the slide inside of the trailer. I have had 4 people try to find it, one of which was an rv tech. Anyone have any idea's?
Okiefatman is offline   Reply With Quote
Old 08-15-2017, 11:21 PM   #2
Check your slide seals. Make sure they are 50% or more pressed together. Go on the roof and make sure the rubber flap is not folded in. You might need to spray a little water on the slide out room and make sure it doesn't pool or gather toward the seal. My first suspicion for a relatively new RV is that the leak is either traveling the wall and ceiling from a slide seal, or there's some water penetration from the trim strip that holds down the rubber roof on the slide top. (assuming water could leak through the screws).
It's just speculation, but that's what I'd be inspecting.
Jason
Boson285 is offline   Reply With Quote
leak, slide
