If you have hydraulic slides as 5picker said, then you should have a series of valves that you can open or close individually. On mine I have three slides and if I want just one open, then I close the other two valves then hit the switch. My valves are in the same compartment as the hydraulic reservoir. Here are a couple pictures of what mine look like. Good luck. Jerry.
