Old 12-12-2015, 03:57 PM   #1
steph45601's Avatar
Slide out help
We have a 371 REBH. It's been winterized and sits at our campground. When we came to check on it the bedroom slide was out. We put them all in. Last time it was partially out and I thought maybe I overlooked it. Starting to wonder? Can something make it come out in its own.
steph45601 is offline   Reply With Quote
Old 12-13-2015, 09:42 PM   #2
Magiccowinuse's Avatar
Not sure what could have caused that. But to prevent it further, consider closing all the valves for the winter. Then they can't open in the case you have something wrong with it.
You can try to diagnose in the spring when you are staying there.
2010 F250 6.4 King Ranch
2015 371REBH
Magiccowinuse is offline   Reply With Quote
Old 12-13-2015, 10:16 PM   #3
steph45601's Avatar
We did close all the valves. It is only an hour away so we will probably check next weekend. Hopefully it's still in. Already has bad A/C and holding tank issue that needs warranty work.
Old 12-13-2015, 10:17 PM   #4
steph45601's Avatar
This fiver is definitely more technically involved than our old 2000 Bounder lol
Old 12-14-2015, 06:29 AM   #5
I vaguely remember this happening to me too. I only had it home for a week and had a ton of other issues I was keeping an eye on. Maybe I didn't close them all they way. But I came out one morning and a slide was about 4" out.
2015 371REBH
Old 12-14-2015, 06:51 AM   #6
It must still have (12V Power) live for the slides to Creep,be it Hyd or Mech? Is is parked on a Hillside? No power and Level parked it will NOT allow slides to Extend! Youroo!! Wait a minute,if the Hyd system is Pressurized and the Valve or Piston is bypassing it can move! Thats IF it is a Hyd. system!
Old 12-14-2015, 02:10 PM   #7
steph45601's Avatar
It is hydraulic. Should be level too. No shore power but battery was still connected. We didn't flip breakers or battery disconnect as maybe we should've before storing.
slide, slide out
