Old 03-15-2016, 11:24 PM   #1
Taking weight off tires
I have heard that long term storage is bad on tires! Has anybody figured how to take some weight off the tires ?
roodman is offline   Reply With Quote
Old 03-15-2016, 11:52 PM   #2
CaptnJohn's Avatar
Put them on a piece of plywood, keep them full of air, and take it for a ride every 6 - 8 weeks at most.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 03-16-2016, 12:18 AM   #3
Ford Idaho's Avatar
Take them off, store them inside laying flat.
Put blocks under the spring bolts.
Old 03-16-2016, 09:38 AM   #4
Tires
Spring bolts, meaning the u-bolts that attach to the axles?.
Where do you actually lift trailer. aka..lift points...Tandem axle, very heavy trailer.
I have put a block between the wheels, on the spring. But did not take the tires off. This seemed to take a lot of weight off, but I am still not happy with the position. Thanks for the help.
mike
Old 03-16-2016, 09:51 AM   #5
On torsion axles, just jack & block between the axles on the frame only. DO NOT JACK on any part of the axles.
Name:	Air-Hyd Jack & Adaptor.JPG
ID:	102058   Click image for larger version
Name:	BJ Adaptor in use.JPG
ID:	102059   Click image for larger version
Name:	BJ Adaptor.JPG
Old 03-16-2016, 02:25 PM   #6
Hi old Coot Where did you get that jack setup? Very nice!
Mo 1954 is offline   Reply With Quote
Old 03-16-2016, 02:34 PM   #7
Made both of them. Carry the bottle jack and adaptor with me and use the air over hydraulic and it's adaptor at home where I have air.
They are both made to lift on the frame with a tab that goes up the other side so the adaptor can't slip off the frame.
Old 03-16-2016, 09:08 PM   #8
Can you give more details on your adapters? Are they made of tubing? How far in does the jack ram set? Great idea. Would like to build a set of my own.
scout3351 is offline   Reply With Quote
Old 03-16-2016, 09:39 PM   #9
Which one? Plain old bottle jack or air/hyd? Can do some measuring and take some pictures tomorrow.
Old 03-16-2016, 10:14 PM   #10
I would probably, like you, use the hydraulic bottle jack on the road and the air over at home. Ideally, they would fit both jacks.
Old 03-17-2016, 11:56 AM   #11
Adaptors are different sizes due to the difference in the height of the jacks and the difference in the diameters of the rams.
Round one is what I carry with the bottle jack. 7-1/4" long, pipe welded inside is 4" long which leaves 3" for the ram to go inside the adapter. The bracket on the side has 3/16" gap to catch the flange on the frame.
Square one is 5-3/4" long and has 1-3/8" for the ram to go inside the adaptor. Bracket on the side has the same 3/16" gap to catch the flange on the frame.
ID:	102147   Click image for larger version
ID:	102148   Click image for larger version
ID:	102149   Click image for larger version
ID:	102150   Click image for larger version
Old 03-18-2016, 05:35 AM   #12
Thanks OldCoot for the detailed info and the pictures. They are added to my list of things to do.
tire, tires, weight
