Old 07-29-2016, 11:20 PM   #11
BandJCarm's Avatar
I wrote an answer and erased it. This is too important for someone with my low expertise to give advise on.
Tireman, or someone that has done this, needs to answer.
I just know what I'd buy if it were me.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-29-2016, 11:32 PM   #12
dannyabear's Avatar
Sailun and goodyear make them in the correct size; don't waste your money on any tire made in china. Have you ever seen a 'towmaster, westlake, or other chinese brand tire store?
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 07-29-2016, 11:57 PM   #13
cj5thwheel's Avatar
Is the goodyear Trailer tire made in USA .They have a Marathon radial tire Load/Ply rating: E/10-ply rating $158.00 each.looks good.
cj5thwheel is offline   Reply With Quote
Old 07-30-2016, 12:06 AM   #14
dannyabear's Avatar
The Marathons were made in china but now made in usa; look on the tire for country of orign
Danny & Darlene
Old 07-30-2016, 12:07 AM   #15
Usually Confused Member
emm-dee's Avatar
Most Marathons made in China now but since they supposedly have a dedicated factory they should be better than the generic brands. 614 tires are USA made.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 07-30-2016, 12:10 AM   #16
Marathon's are no better than towmaster or greenball. All made in china. There is a jillion different china tire brands....most of them are crap. . I dont think IVe heard of anyone happy with towmasters. About 4 years ago, I bought a set of greenball tires. They lasted 2 years before they started blowing. Lost 3 tires within 6 months. IF your rims are rated at 110 psi, get the Goodyear G614's. Probably the best tire made. But they are not cheap. Roughly $325 each depending.
If the G614's are a no go, then look at the Maxxis 8008. I just put a set of these on a couple months ago. So far so good.
Also, consider a tpms.
Good luck.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 07-30-2016, 12:19 AM   #17
I was looking in Costco at the green ball told Master SS Special trailer Radial Tire in my size and they have a good rating
They have a good rating by who? I'm thinking they are just another cheap Chinese ST blowout waiting to happen. You will get what you pay for with cheap trailler tires.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 07-30-2016, 12:21 AM   #18
dannyabear's Avatar
The Sailuns are around $175 ea, and the GY G614 is around $325 each
Danny & Darlene
Old 07-30-2016, 12:36 AM   #19
I use Firestone Transforce 265/75 R16. They are the same physical size as the 235/85 R16 which are only slightly larger Outside Diameter than the 235/80 R16. If you inquire on a tire size chart you can see the difference in sizes. The reason I use the 265/75 R16 is that is the size that came as original equipment on my F-250 and they are load rated a little over 400 more pounds capacity each than the 235/85 R16. I have used the Firestone Transforce for several years on different flatbed trailers hauling heaver loads (commercially) than my CC 30LSTS. Those trailers were using the 235/84 R16 tires. When I switched to using these tires, I stopped having blowouts on my trailers. Not a recommendation, just my results.
03 F-250, 7.3 L, CC, Lariat; 07 Cedar Creek 30 LSTS Silverback; the DW and me.
dnismenace is offline   Reply With Quote
Old 07-30-2016, 02:05 AM   #20
Airdale's Avatar
I'm looking to pick up new tires for my Sierra 40 footer and I want to go into light truck tires but I need 235 - 80 - 16 and they don't make it in a light truck tire what do I need to do to go to a light Truck Tire in that size the only truck tire I know is a 245 75 16 and I don't know if it will fit my trailer has anybody run into this would appreciate some information
I'm just going to guess that you have GAWR axles around 6750#. You can look on your certification label to confirm that.
None, Zero LT235/85R16E tires or any other LT 16" LRE tires are qualified for use on those axles.
You're gonna have to start thinking tire/rim packages for replacements if you want american made stuff.
The best and most durable packages will most likely be found in the 17.5" tire rim sizes.
The American made LT235/85R16G tires are expensive but qualify for your axles at 3750# at 110 PSI but they require a 16x6.5" rim with a high pressure 110 PSI rating.
New, more beefy 16' ST tires are coming from over there. Their ratings are 4080# at 110 psi and all that I've seen have a 75 MPH speed rating.
Good luck, and research, research, research!
USN - RET - PDRL
DOD - RET - Journeyman Aircraft Mechanic
SSA - RET
Airdale is offline   Reply With Quote
light, tire, tires, trailer, truck
