Old 07-29-2016, 09:32 PM   #1
cj5thwheel's Avatar
The difference between trailer tires and light truck tires
I'm looking to pick up new tires for my Sierra 40 footer and I want to go into light truck tires but I need 235 - 80 - 16 and they don't make it in a light truck tire what do I need to do to go to a light Truck Tire in that size the only truck tire I know is a 245 75 16 and I don't know if it will fit my trailer has anybody run into this would appreciate some information
cj5thwheel is offline   Reply With Quote
Old 07-29-2016, 09:39 PM   #2
BandJCarm's Avatar
http://simpletire.com/goodyear-lt235...PhnBoCBZPw_wcB
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-29-2016, 09:39 PM   #3
If your wheels are 110 psi rated buy the sailun s637 tires they are great. Much heavier than the lt's
2013 365 SAQ
Rufinit is offline   Reply With Quote
Old 07-29-2016, 09:46 PM   #4
Usually Confused Member
emm-dee's Avatar
Or the Goodyear G614
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 07-29-2016, 09:50 PM   #5
cj5thwheel's Avatar
I have aluminum rims I don't know what the rating is on them for the PSI
Old 07-29-2016, 09:57 PM   #6
cj5thwheel's Avatar
I was looking in Costco at the green ball told Master SS Special trailer Radial Tire in my size and they have a good rating
Old 07-29-2016, 09:59 PM   #7
cj5thwheel's Avatar
It's a tow Master tow they sell for 106.99
Old 07-29-2016, 10:01 PM   #8
BandJCarm's Avatar
Tow master is Chinese. Aluminum rims are rated higher than steel rims, I believe.
If I get another set of tires, it WILL be LT rated tires........99% sure it'll be the G614's in that size. I'm not spending money on anything less than those, to change tires.
FROG AR-0019-242
Old 07-29-2016, 10:09 PM   #9
cj5thwheel's Avatar
Can I use a 245 - 75 - 16 Light Truck Tire being that I should have 235 - 80 - 16
Old 07-29-2016, 10:19 PM   #10
cj5thwheel's Avatar
Thanks a lot guys I appreciate all the info you gave me
light, tire, tires, trailer, truck
