Closed Thread
Old 08-07-2012, 04:12 PM   #1
Third AC on 202 Sierra 330RL
Has anyone installed a third AC in the Living Room Vent on a 2012 Sierra 330RL?
Foster11 is offline
Old 08-07-2012, 05:56 PM   #2
Hello, and to the forums. As your question, NO. You don't have the power capacity to run 3 AC units. If 3 AC units were to try and start compressors at the same time, it would be 60 amps or more. Now add microwave, television, water heater if electric, and there is no way a 50 amp service will handle it. 50 amp service is the max you will find at a campground.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
LadyWindrider is offline
Old 08-09-2012, 04:39 PM   #3
Most places that have 50 amp have a 30 amp to!!!!! I have three a/c's i use a 50 and a 30, i suggest it to everyone, i love it!!!!!
Smoo is offline
Old 08-09-2012, 05:57 PM   #4
Most places that have a 50 and a 30, and a 20 amp hookup, aren't designed or wired so that you can add them all up and get 100 amps. The plugs are parallel, and the most you can get out of the pedestal is usually 50 amps, or 60 amps, 30 per side of a 220 feed. Maybe you have been lucky, or don't camp in super weather, or don't run a lot of other electric stuff.
LadyWindrider
Old 08-10-2012, 07:01 AM   #5
I use all three all the time, and a electric hot water heater, microwave and three tv's, works great trust me
Smoo is offline
Old 08-10-2012, 07:09 AM   #6
And i also have a deep freeze on the back that i plug into the 20 amp plug too
Smoo is offline
Old 08-10-2012, 07:21 AM   #7
caper's Avatar
Smoo are you willing to pay extra for your site? You are paying for a 50 amp site not a 50 and 30 amp. You are stealing from the campground when you rob extra power. The owner has to make a profit and if everyone did what you are doing the cost of camping will go up in order to off set the costs.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
caper is offline
Old 08-10-2012, 07:41 AM   #8
Some places do charge more, so yes i do and would pay more!!!! Its no different than running electric heaters in the winter, some charge more for that....
Smoo is offline
Old 08-10-2012, 10:43 AM   #9
Wow looks like i am the only one with three a/c's on and for that i get acused of it no working and stealing...... What a world we live in!!!!!
Smoo is offline
Old 08-10-2012, 05:49 PM   #10
caper's Avatar
If you are using more then one plug on the electric post you are stealing power. The post is wired for all three but this does not mean you can plug into all three outlets. When you register for a site you are asked if you want 50, 30 or 20 amp service. You are then charged for the service you choice. When you plug you unit into the 50 amp service and then plug into the 30 or 20 amp you are stealing hydro from the campground. The only time I will use more then one plug is if i am on a meter and am paying for all the hydro that I use.
Terry and Janet
2007 Ford F150
caper is offline
Closed Thread
