Old 03-21-2018, 08:21 AM   #1
Half-Timer
Tire 235 85/16 vs 235 80/16
I am thinking of replacing my 235 80/16 tires with 235 85/16. My reason is a slight (`400 lbs) increase in max load per tire. The 85's have a one inch increase in diameter (1/2 inch radius) so I do not see any negative effects. There is a slight increase in price but I believe the added max load is worth the extra cost.
Does anyone have experience in going to 85 vs 80 tires?
I have a 2017 Sierra 378 FB.
Enjoying God's creation each day.
2015 Ram 3500 Laramie Limited with 6.7L Cummins Diesel
Forest River Sierrra 378FB
ptylerp is offline   Reply With Quote
Old 03-21-2018, 08:41 AM   #2
AquaMan's Avatar
You would be better off going up in load rating than in size, assuming that both tires were of the same load rating just different specs. If going up in load rating, make sure your rims can handle the pressure.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 03-21-2018, 08:57 AM   #3
Half-Timer
Looking at Goodyear endurance and they only come in Load range e.
Old 03-21-2018, 09:22 AM   #4
I replaced my Chinese ST 235 80/16 E to Michelin RIB LT 235 85/16 E back in 2006 on my 5th wheel. I've pulled thousands of miles with no negatives to report. I've replaced the RIBs due to age but not mileage or other effects (most of the tread-depth remained). As long as you have the physical spacing between axles to handle the increased diameter and the tires meet the weight requirements, I'd go for it. By the way, the tire weight of the RIBs is significantly heavier than the Chinese OEM tires. Inflation is the same for either,80 psi.
wlstroud is offline   Reply With Quote
Old 03-21-2018, 09:26 AM   #5
Jim34RL's Avatar
You should measure the rolling tire clearance between the frame, sidewall and between both tires to insure proper fit. Also make sure that the rim will except the tire profile. The tire dealer should be able to provide these dimension to you.
On one of my previous campers I switched out the ST Power King tires, ST235/80R/16 to a Michelin XPS RIBS, LT245/75R/16E. The tires had a slightly different rolling radius and I made several measurements before buying the new tires to insure clearance and fit. They worked very will along with a higher load rating than the pervious Power Kings that came with the trailer.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 03-21-2018, 01:36 PM   #6
Blog: RVroadtripper.com
hbillsmith's Avatar
Here's some recent research I did on this subject. Note that you can run the popular Sailun 235/80/16 at 80psi and they are Load Range E with 3,480 lbs carry capacity. If your wheels are rated for 110psi, you can run the same tire at 110psi and they are Load Range G with 4,080 lbs. carry capacity. I currently run the Maxxis and have had good experience with them. I'm on my second set of Maxxis simply because I wanted to change them early (@12,000 miles) before I head to Alaska.
Name:	Compare Five ST and LT Tire Specs.jpg
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 03-21-2018, 02:37 PM   #7
Airdale's Avatar
Notes and references for future endeavors:
1: All LT245/75R16E sized tires have a minimum rim width requirement of 6.5".
2: https://www.michelinman.com/US/en/he...res.html#tab-4
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is offline   Reply With Quote
Old 03-21-2018, 02:41 PM   #8
Airdale's Avatar
Michelin considers that a misapplication of their tire. The reference points out why.
Note: The Michelin XPS Ribs are retreadable.
Old 03-21-2018, 03:44 PM   #9
Switch to bigger tire 80 vs 85
I did that last year. Was the best thing I ever did. Gave piece of mind due to more load carrying capacity. No problem with heat buildup. Rode great and pulled great. Little bigger diameter did not make any difference on clearance.
So if clearance is not a problem, my advice is to go for it.
dlewand53 is offline   Reply With Quote
Old 03-21-2018, 05:23 PM   #10
CaptnJohn's Avatar
I replaced my Rainier ST 235 80/16 E after pulling 43 miles with Sailun 235/85/16. All fit and pull great! Actually, the 85 were only 4 months old and $10 less the 80 each.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
tire
