Old 03-29-2013, 09:25 PM   #1
Tires, Tires, Tires....
So I've been nervous about my tires ever since my first trip with the 365SAQ the week after we brought it home. While Driving across Tennessee I had a tire start to fall apart - literally treads separating from tire. I caught the issue before it blew out and put the spare on.... Forest River claimed it was a bad run and I'd be fine.
I haven't had any more problems with the tires, but we're heading to Florida later this year and the long run has me concerned again. I've been doing my homework and I got down to the Goodyear G614s and the Michelin XPS Rib. I was just advised by a tire dealer though that the 110PSI operating pressure of the 614 was too high for the stock wheels on my rig. That leaves me with the XPS. Does anyone on here have any direct experience with the XPS, or an alternative option that I haven't seen identified somewhere?
I know tires are sometimes a sticky topic as most people are quite opinionated and I'm not looking to start a riot - just trying to get some piece of mind and real world experience before a drop $1000+ on replacing the china bombs currently installed on my trailer. Thanks!
2013 Forest River Sierra 365SAQ, 7000# Axle Swap, 5th Airborne Air Ride
2010 Chevy 2500HD D/A, CC, Timbrens, Curt Q16 Slider
Nights Camped in 2015 -- 40
Nights Camped in 2016 -- 26
cfisher523 is offline   Reply With Quote
Old 03-29-2013, 09:48 PM   #2
Helmsey's Avatar
I think the Ribs are one of the more popular replacement tires used, especially for the heavier rigs.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 03-30-2013, 04:04 AM   #3
golfmedik's Avatar
If you have 6k axles under yours, then most of the wheels will not take 110 psi. I got really lucky and my 6k wheels were rated for that. Call Tredit Tire - Tires and Wheels for RVs and Trailers or go to the website and look at this one T03 It has a rating of 3580 pounds per wheel, plus it is 6.5" wide as required for the G614s and it is 6 lug. Wheels from here are not that expensive as they are the OEM suppliers to the RV industry as well as boat, car and horse trailer markets. IT is where my new wheels came from when my axles were switched. This wheel should enable you to use the G614s or any other 110psi tire out there. Also you might want to look at this tire as it is becoming pretty popular $192.21 - Sailun LT235/85R16 8244393 tires at SimpleTire.com I believe they are made in Canada, but a good option for the other expensive G rated tires.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 03-30-2013, 06:46 AM   #4
Originally Posted by golfmedik View Post
If you have 6k axles under yours,...
Wow, 12 tires? Very expensive to replace!
Old 03-30-2013, 06:49 AM   #5
golfmedik's Avatar
Oooops....took me a while.. I meant to say "if you have 6k pound axles" hahahaha That was funny!!!!
Old 03-30-2013, 07:44 AM   #6
rattleNsmoke's Avatar
Check out Cooper SRM II tires. They are American made, good reviews and relatively inexpensive. I own them and have good luck for 5000 miles so far.
http://us.coopertire.com/Tires/Light-Truck/SRM-II-RADIAL-LT.aspx
rattleNsmoke is offline   Reply With Quote
