Old 07-31-2014, 09:48 PM   #1
rbcdp98's Avatar
Trim pulling away from skirting 365 saq
I'm having a problem with my trim above the metal skirting pulling away. Does anyone know how they adhere to the sides. Click image for larger version
Name:	ImageUploadedByForest River Forums1406861218.567845.jpg
rbcdp98 is offline   Reply With Quote
Old 07-31-2014, 10:14 PM   #2
jtstromsburg's Avatar
If it's what I think, I had the same on my sabre. I had the dealer pull it all off, clean the caulk off, then re-install with screws and caulk the top. Seems much better now. There was screws originally, but only every 4-6 feet. Mine was mostly a problem on the slides.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 08-03-2014, 01:12 AM   #3
rbcdp98's Avatar
Mine has no screws visible. So far it's only happening on my kitchen/living room slide. Thanks for the reply.
Old 08-03-2014, 01:20 AM   #4
Plain Old Member
I believe that trim just snaps on. It covers the screws that secure the skirting to the side wall. I'm not exactly sure of the trick to get it off though. We have the same trim. If I were to try it, I'd probably gently pry the bottom up working my way down the trailer.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
365, 365 saq
