Old 11-10-2012, 09:09 PM   #1
TV mud tires for pulling 353QBQ?
I'm torn, it's time to get new tires on my TV. I current have 35" A/T tires on the stock 17" rims on a SRW 3500. They were D rated tires and they just didnt hold up to the pressure on the tread structure, meaning I was breaking chunks off. I just don't like the way they look either.
I was thinking of moving up to a 20" rim and a stronger E rated mud tire. Lots of choices here, but not sure about the towing experience with the make up of this kind of tire and rim combination.
Our camping radius is about 8 hours in Oregon/Wash, and don't plan to travel farther until the kids get a little older. So I spend most of my time commuting to work and back which is only 5 miles away from home.
Any recommendations from experience?
PGM
2007.5 Dodge RAM 3500 Mega Cab SRW
Mods: stiffer shocks, airbags, exhaust
Prodigy BC, Reese 20k Dbl-Pivot Slider Hitch
2011 Sierra 355QBQ, Mega Couch, Outdoor Kitchen
meritage98 is offline   Reply With Quote
Old 11-10-2012, 09:45 PM   #2
Missing Link
cyclepuck's Avatar
A buddy has 20" copper stt's on his f350 and has had really good luck with them. No much road noise, wear good and carries the weight without any problems.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 11-10-2012, 10:21 PM   #3
jonnys_walkers's Avatar
I run Toyo "E" rated tires.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 11-10-2012, 11:15 PM   #4
wyo700's Avatar
I try to talk your self out of mud terrain tires. Especially if will be hauling your trailer. I know the mudders look really good but unless you will be in the mud or rock crawling or on the trails all the time and not much highway and which you may. But if not dont get them I think you won't like them for driving down the highway and for pulling the camper. I was the same way I had chrome rims with BFG mudders on my Titan. Now my Titan has the stock rims back on with with Michelin AT2 tires load range d and its the best thing I have ever done.
And if you were chunking tires that has nothing to do with it being a load range d tire you could have the same tire in a E range and it would have done the same thing. That the the way the tread compound is not the load range.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is online now   Reply With Quote
Old 11-11-2012, 02:18 AM   #5
Wow, this is all great feedback folks. Must appreciated.
PGM
Old 11-11-2012, 07:27 AM   #6
Wanna Be Camper
SaskCampers's Avatar
I would consider Nitto Terra Grapplers, Hankook DynaPro AT/M or Toyo Open Country's in the size you want. They are not mud tires but an A/T and would be much better suited to your use and all 3 have a very nice profile and are all rated very good. I had 285 70 17 Hankook DynaPro's on our 08 2500 Megacab 4x4 and they looked very nice as that is the size the power wagons come from the factory with. These tires are all very stable and quiet. FWIW I live in the country and drive abt 40 -50 miles a day on dirt roads that get very muddy in the spring and these type of tires have not let me down, slow and steady wins the day in the mud. BTW you really should be running LR E tires on that thing.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 11-11-2012, 08:57 AM   #7
i have been running bfg mud terrains for almost 20 years and i am on my 3rd set. i have a 31b2 silverback ceadar creek fifthwheel that is 38 fett long and 14000 lbs. the tires are great on the highway. just make sure you buy e load range. i have had many friends run cheap mud tires and they just fall apart. i get around 150,000 miles to a set.
18 3500 denali duramax cc srw
silverback 31b2
skidoonut is offline   Reply With Quote
Old 11-11-2012, 09:22 AM   #8
wyo700's Avatar
A, really what are your bfgs made out. 40000 out of any mud terrain is good. Haha heck it's not even possible to get this out a car tire let alone any truck tire. Especially with the weight of a camper on the back. I am not trying to bash here but this info has to be false and others looking to buy tires shouldn't get this impression.
2013 Toyota Tundra
Old 11-11-2012, 11:38 AM   #9
Dave_Monica's Avatar
X2
Load range D tires are probably less than the axle rating on the truck...should be above.
Dave
Old 11-11-2012, 05:55 PM   #10
BigTJohn's Avatar
20's will LOWER the tow rating of your truck. 17's are better and a load range E will be good. I had 33k + on my GY tires with about 8k miles towing. Still had reasonable tread left, at least another 10k. Look at the specs for your TV and you can see how different size tires affect your towing ability.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 11-11-2012, 06:19 PM   #11
ironj's Avatar
i have towed with my trail grapplers on......they are nitto 35-12.5-20's ...works fine, is a lil loud, and dont get as good mpg....they look awesome tho....LOL...this is an LT E rated tire....3100lbs at 65psi....i love these tires btw....
normally i just swap the stock 20's on ...better gas mileage....
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 11-13-2012, 12:13 PM   #12
sorry i am from canada. i should have said 150000 km.
silverback 31b2
Old 11-13-2012, 01:02 PM   #13
wyo700's Avatar
No need to apologize just thought that was way off.
2013 Toyota Tundra
Old 11-13-2012, 01:14 PM   #14
That's still 93000 miles, I'm sorry, but I find it very hard to believe you can get that kind of milage out of any tire. Even on my car it's hard to get 90000 KM out of them.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 11-13-2012, 01:24 PM   #15
wyo700's Avatar
I didn't do the calculations but ya no way.
2013 Toyota Tundra
Old 11-13-2012, 03:17 PM   #16
daydreaming about camping
jeeplj8's Avatar
I got 90K out of a set of BFG long trials that came OEM on my 2500 Ram. That is all highway miles. I have 45K on my current Hankook dynapro ATM and think they will make 80K.
As to OP - you have gotten some good advice here. get a good qaulity load range e tire. and many people report that their towing experience on 17's is better than 20's.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 11-16-2012, 09:30 AM   #17
Oklahoma Proud
MillerTime's Avatar
I use mud tires on my diesel trucks, with the heavy front end and driving in pastures and off road a lot. I have 295-70-18 (34.5"tall) nitto trail grapplers, load range E- 4080Lb single @80psi. I put these on in feb. only have about 5k on them. Before them I had 285-75-16 (33.2" tall) Hankook Dynapro M/T. I didn't rotate and the rears were @ about 2/32-3/32 and fronts @ little over half tread at 19,000 miles, and 3years old.
My have not seen tires "chunk" out unless they spend considerable time on gravel roads or are fairly old. But alignment and cheap tire compounds could also possibly cause it.
$0.02
