Old 11-07-2016, 07:21 AM   #1
Water Filter
2017 Sierra 401 FLX has an EXTERNAL Camco Hydro Life HL-200 system mounted inside and under the galley. Not sure WHAT I need to do before winterizing? There is a blue "push?" button on top and wonder what that is for ??
dcavaiani is offline   Reply With Quote
Old 11-07-2016, 09:30 AM   #2
AquaMan's Avatar
Remove filter and fill canister with golf balls or put a full water bottle inside, then winterize. The golf balls or bottle helps reduce the volume so you use less antifreeze. If the water bottle is empty, the pressure will crush it and not save you much.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 11-07-2016, 11:04 AM   #3
That sounds great. Never took out/replaced a filter b/4. Is it simple to do?
Old 11-07-2016, 11:23 AM   #4
Make sure you turn of water supply (city water or pump) and then open a faucet to relieve pressure. The canister should come off easily then.
Many units also come with a supplied housing wrench. Mine was in with all the manuals. Some have said it was in a drawer.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 11-07-2016, 12:09 PM   #5
Left Coast
The button on top might be for bleeding air out of filter when it's empty
Old 11-08-2016, 12:56 AM   #6
jk510's Avatar
The button is probably a pressure release. I think the suggested opening of the faucet is the better idea as you will get some water released as well as pressure, if you know what I mean.
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
water, water filter
