Old 08-13-2017, 02:15 PM   #1
Water filter housing.
I have a Sierra 5th wheel 376BHOK, and I can't seem to get the water filter housing off to put a filter in there. I tried pushing up and twisting it, but I don't want to break it. Any ideas?
Thank you
Mcnet22 is offline   Reply With Quote
Old 08-13-2017, 02:21 PM   #2
Take the water pressure off by opening a faucet or two. Some you have to push up while turning. Relieving the pressure is the big thing.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 08-13-2017, 02:42 PM   #3
Canadian Member
Thank you
What model is your water filter housing?
2019 Rockwood Signature 8290BS
Old 08-13-2017, 08:40 PM   #4
Model FR1
Old 08-13-2017, 09:20 PM   #5
what has been said before. turn off water and open a faucet to relieve all water pressure. use two hands to push up while turning canister counterclockwise (when viewed from the bottom). there are some locking teeth on the top of the canister. pushing up helps release them. it will break loose. they make a plastic wrench that slips over the canister (it engages the four ribs on the canister) and gives you more leverage to remove / install the canister. they are about $8 on-line. I have one and it helps. just take it slow and steady.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 08-13-2017, 09:22 PM   #6
Thank you very much
Old 08-13-2017, 09:43 PM   #7
After you've opened it, REMOVE it before the casing cracks and puts water all over the floor of your TT. LOTS of people reporting cracking/leaking of FR1's. Install a 67 cent Home Depot 1/2" coupler in it's place.
Name:	Filter replacement coupling.jpg
ID:	148140   Click image for larger version
Name:	Filter removed.jpg
2011 Traverse LT, 3.6L, FWD
Old 08-13-2017, 09:55 PM   #8
Dakota EV's Avatar
This is a great idea. I have been trying to figure out how to remove my filter housing without taking the walls apart and I did not think about doing it this way. Thanks, great post.
Freddie & Linda
2015 FR Sierra 330RLS & 2003 Dodge 2500 4X4 CD
TMPS for Camper & TV
Days Camped for 2017 - 128
Days Planned for 2018 - 42
Dakota EV is offline   Reply With Quote
water, water filter
