Old 02-08-2016, 04:16 PM   #91
I guess I spoke too soon. They just called me because they are trying to get authorization to lift my rubber roof to fix the the aluminium flashing that is along the top edge of the walls.
PSEYFRIED is offline   Reply With Quote
Old 02-08-2016, 06:32 PM   #92
Good luck with that. I have the same issue and apparently a lot of people do. FR denied the warranty repair saying its just cosmetic and does not affect the performance of the fiver.
Sierra360PDEK is offline   Reply With Quote
Old 02-08-2016, 06:58 PM   #93
I hear ya. I noted the issue a month after I took delivery and I told the dealer that I heard it popping and now they are going to photo it and resubmit it to FR.
Old 02-10-2016, 02:11 PM   #94
Dakota EV's Avatar
The same thing happened to my roof and I was able to get my dealer to contact FR and they finally agreed to pay to have the dealer repair the problem. The roof looks great now but I still have water leaking into my front cap. FR refuses to do anything about the water leaking problem but I think that they should. I wished that I was rich enough to afford a lawyer because I would take FR to court on this problem. There are too many of us having this leaking problem for this not to be something that the factory screwed up. But I will just have to keep looking until I find and fix the leak problem.
Freddie & Linda
2015 FR Sierra 330RLS & 2003 Dodge 2500 4X4 CD
TMPS for Camper & TV
Days Camped for 2017 - 128
Days Planned for 2018 - 42
Dakota EV is offline   Reply With Quote
Old 02-10-2016, 03:28 PM   #95
Well if mine leaks after this time it is going back to the factory
Old 02-21-2016, 08:04 AM   #96
Dakota EV's Avatar
Has anyone had any luck fixing the leaks on the front cap. I am still chasing my leaks down and I have not found the problem yet. Guess that I will keep looking.
Freddie & Linda
Old 02-21-2016, 12:28 PM   #97
See my response about 7 posts back. Bone dry since I repaired the seams
Old 02-21-2016, 09:01 PM   #98
SKnight's Avatar
Mine is still dry. I posted the fix, I believe, but they pulled the sealer, said they didn't like the way the rubber roof was folded in, fixed that, then resealed it side to side.
We found one last little leak, the side marker light at eye level was filling up and letting water run in past the bulb. Both lights were sealed up, so far it's been bone dry.
Old 02-26-2016, 03:28 PM   #99
Dakota EV's Avatar
Unhappy
I completed the repair to the seam just as you showed and I am still getting water in the Nose. Guess that I will keep looking.
Freddie & Linda
Old 02-26-2016, 06:54 PM   #100
Well darn, that sucks. Have you checked the clearance lights near the top of the cap? I would also closely inspect the entire cap for any cracks.
I wish you the best of luck my friend. Sorry can't be of more help.
5th wheel, water, wheel
