10-27-2016, 11:35 AM
#141
Our fifth wheel is leaking like this too. Hubby just used self-leveling LAP sealant on the roof, as well as non-leveling LAP on the corners where the gutters are. We removed the plastic trim underneath the nose cap (on both the left and right sides) and see water slowly dripping out with some rusty screws along the metal seam (that holds the nosecap to the body). I hope to God we've discovered the cause of the leak, because we really can't afford to take it in to get it professionally done since we purchased ours from a private party.
06-07-2017, 11:07 PM
#142
Originally Posted by Dakota EV
Just a word of warning, I had to redo all of the original caulking that the factory did on my sierra. I also used the EternaBond white roof tape and the self leveling caulking to seal the seam on the roof. But I believe that it was the caulking around the front seal that was allowing the water to get into my nose cone. I used two tubes of Geocel 28100v Pro Flex Crystal Clear RV flexible sealant to caulk both sides of the cap, marker lights and everything that I could see that looked like it might leak. I have learned, from this experience, to take nothing for granted when it comes to what the "Factory" is supposed to do. I really love our camper but I believe that Forest River is letting us down when it comes to really checking out their work on these campers.
We too had serious water coming out where the front jacks are. Especially when we hooked up the camper to take it back to dealer to get window leaking fixed. Have you had anymore water issues since you resealed front end?
Originally Posted by PSEYFRIED
I believe that. Mine did the same thing when I was hooking up. Poured out by my front jacks.
Originally Posted by Hoser2eh
That video was taken after I raised the front jacks!
Originally Posted by Sierra360PDEK
No water ever made it inside the coach just the nose. I caught my leak early and was able to make the repairs quickly. Get yourself a 4" roll of Eternabond tape and seal your roof at the cap and EPDM roof. Also look just above the gutter where the spout is and make sure it's properly sealed.
06-08-2017, 10:42 AM
#143
I have not seen any more water coming from the nose section of our Sierra since I sealed it. We have been to a lot of different CG and the camper has been through some pretty heavy rain. We have even washed the camper twice since then with no leaks that we can see. I hope that this helps you with your camper. You just need to really seal the front cap good and use good sealer. The tape that I used was also a good idea. I even bought a new roll of it just to take with us when we go camping. In case we see any water where it should not be.
Happy camping.
Freddie & Linda
2015 FR Sierra 330RLS & 2003 Dodge 2500 4X4 Diesel
TMPS for Camper & TV
06-12-2017, 08:51 AM
#144
2015 371rebh. Used it this weekend, have noticed the same issue with water coming out when moving the jacks. Looked in my front closet and found that the shelf with the clothes rod had been wet. Its compressed wood so now it's swollen and broken up....
06-13-2017, 10:40 AM
#145
I got pounded in a hailstorm that knocked out both of my roof vents, but the front cap is still dry.
06-13-2017, 11:06 AM
#146
You have to inspect and repair your roof and seams at least once a year starting from the first time you bring it home. Dicor is cheap and easy. Eternabond works well also for a longer lasting repair. No seam/protrusion sealer works indefinitely.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
06-13-2017, 11:21 AM
#147
this makes me mad. I had this issue and FR denied the claim based on the dealer not maintaining the seals on the lot since it had sat for awhile
its a NEW trailer regardless. I shouldn't leak for 90 days
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
06-25-2017, 10:43 AM
#148
We are hitching up our new sierra 378fb for our first trip. We had a hard rain last night and this is happening. Is this the same as everyone on the post? ie. Bad seal on front cap ??
06-25-2017, 11:11 AM
#149
I would get up on top and take a look.
06-25-2017, 11:23 AM
#150
Location: Alberta - East of the Rockies, West of the Rest
This is definitely a warranty issue.
The point of entry could be as far as 10' away where you would least expect it, don't ignore the slideout openings as potential culprits.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
06-25-2017, 11:25 AM
#151
X2, and check the seals around the clearance lights.
John Taylor
2019 Newmar Bay Star 3609
2018 Cardinal 3350RLX - sold
2013 Cardinal 3030RLS - sold
06-25-2017, 11:31 AM
#152
Yes, this is the issue I had. See my previous post on how I fixed ours. Good luck.
07-07-2017, 07:13 PM
#153
I have a new 2017 Sierra 3350BH I have same issues . Call fr rep. Good luck
10-30-2017, 08:00 PM
#154
2016 Sandpiper
Wet inside closet on top shelf after 2 storms..noticed and put a sealer on obvious cracks I found in seam.
Anyone else have that?
