Old 07-12-2012, 08:56 PM   #1
water leak
Our 365saq started leaking water out of the city water conection when ever the pump is on. Is this just a stuck check valve? thanks Todd
tfedd is offline   Reply With Quote
Old 07-12-2012, 09:23 PM   #2
Usually that is all it is. May take a wooden match, and press on the little plunger in the center once or twice and make it stop. May just be a piece of trash. Turn the pump off, and bleed a little pressure off before you do this. If not, some can be taken apart and a new "o" ring installed.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
