Old 12-22-2016, 03:02 PM   #1
Water Pump Location
Hate to ask a dumb question, but I've been searching the forms and my 5th Wheel in search of my water pump. We have a Sierra 346RETS.
Thanks in advance for the help!
flywnc is offline   Reply With Quote
Old 12-22-2016, 03:21 PM   #2
First post... welcome to the forum.
Never a dumb question.
Does it not work or are you just trying to locate it?
Often times if you open a faucet slightly (with the on-board pump on) you will be able to hear it cycle on and off. Just follow the sound.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 12-22-2016, 03:31 PM   #3
My fresh water holding tank is filling up while I'm connected to city water.
Fresh water tank filling itself when connected to city water Help!
I tried the suggestions listed in the above link without success so figured I would take a closer look at the pump if I can locate it.
Old 12-22-2016, 03:42 PM   #4
tapex's Avatar
Welcome to the forum! from Farmer, N.C.
2016 Coachmen Apex 250RLS Ultra Light
'19 Ram Big Horn Lonestar Sport
(3)yrs.=(865)Days
tapex is offline   Reply With Quote
Old 12-22-2016, 03:50 PM   #5
rracer5's Avatar
I can almost guaranty that it's behind your docking/hook up station. You will probably need to take some of your basement walls down to gain access.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 12-22-2016, 10:34 PM   #6
chop249's Avatar
What racer said. That's where I found mine. I was looking for it because it was acting funny, but I realized that it doesn't shut down entirely reliably unless you've bled all the air from all of the lines. Mine would continuously hum after I shut the water off at a faucet. FINALLY figured it out.
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 21/18 = 11
chop249 is offline   Reply With Quote
Old 12-25-2016, 11:01 AM   #7
Water pump will not suck antifreeze into the system on a 2015 REV. I have been told the control to select the water input function has O rings that dry out and can cause this??
jl7796 is offline   Reply With Quote
cat, location, pump, water, water pump
