Old 12-22-2016, 03:02 PM   #1
Water Pump Location
Hate to ask a dumb question, but I've been searching the forms and my 5th Wheel in search of my water pump. We have a Sierra 346RETS.
Thanks in advance for the help!
flywnc is offline   Reply With Quote
Old 12-22-2016, 03:21 PM   #2
First post... welcome to the forum.
Never a dumb question.
Does it not work or are you just trying to locate it?
Often times if you open a faucet slightly (with the on-board pump on) you will be able to hear it cycle on and off. Just follow the sound.
Old 12-22-2016, 03:31 PM   #3
My fresh water holding tank is filling up while I'm connected to city water.
http://www.forestriverforums.com/for...lp-104655.html
I tried the suggestions listed in the above link without success so figured I would take a closer look at the pump if I can locate it.
Old 12-22-2016, 03:42 PM   #4
Tapex's Avatar
Welcome to the forum! from Farmer, N.C.
2016 Coachmen Apex 250RLS Ultra Light
2023 Ram 2500 Big Horn Sport 3.73
Tapex is offline   Reply With Quote
Old 12-22-2016, 03:50 PM   #5
rracer5's Avatar
I can almost guaranty that it's behind your docking/hook up station. You will probably need to take some of your basement walls down to gain access.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 12-22-2016, 10:34 PM   #6
chop249's Avatar
What racer said. That's where I found mine. I was looking for it because it was acting funny, but I realized that it doesn't shut down entirely reliably unless you've bled all the air from all of the lines. Mine would continuously hum after I shut the water off at a faucet. FINALLY figured it out.
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 21/18 = 11
chop249 is offline   Reply With Quote
Old 12-25-2016, 11:01 AM   #7
Water pump will not suck antifreeze into the system on a 2015 REV. I have been told the control to select the water input function has O rings that dry out and can cause this??
jl7796 is offline   Reply With Quote
cat, location, pump, water, water pump
