Old 07-21-2014, 11:14 AM   #1
weird question about shower floors
Can you check.....Did anyone notice the shower floor appears to be "padded" underneath. or did I have a major leak under mine and the floor is all rotted? ie; when you stand in the shower it does not feel like you have and are standing on a hard/solid piece of wood underneath. Use your heel if you are not sure. 2014 365saqb sierra. Thanks.
quick83 is offline   Reply With Quote
Old 07-21-2014, 11:16 AM   #2
SKnight's Avatar
That's exactly how mine feels. Once my dealer told me it's normal I actually find it nice.
Old 07-21-2014, 11:18 AM   #3
NELA
Weezer's Avatar
There is flex in the floor of our shower stall, true on the V-Lite we bought last year, and the 5er we bought in January...both from day one.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 07-21-2014, 11:23 AM   #4
wow thanks guys for the quick response. I also love the way it feels on you feet and just wanted to know it was normal.
Old 07-21-2014, 11:38 AM   #5
5 hole's Avatar
for home builds contractors will use expanding spray foam to fill gap between OSB floor and tub or shower bottom, not sure if they use this practice in the RV's but that could be what you are feeling.
Stefan
2014 - Sabre 36 QBOK
Nights camped 2014 - 38
Nights camped 2015 - 46
Nights camped 2016 - 43
Nights camped 2017 - 2
5 hole is offline   Reply With Quote
Old 07-21-2014, 11:51 AM   #6
5 hole I think you got it exactly..that's what it feels like thanks.
Old 07-21-2014, 12:10 PM   #7
NO,it is NOT padded,remove the access panel and you (Will/could) find that the (Plummer/installer of the shower pan,cut a (HUGE/BIG) hole in your floor to install the Trap! You will (Will/Could) find the shower (Floor,Pan) supports in (Mid Air) NO contact with the floor! You will have to build a (Bridge/Truss) support across the (Cutout Area)! This is what I have done on a (Few) to fix the (Nice Padded Shower Floor)? Youroo!!
ID:	58595   Click image for larger version
Old 07-21-2014, 12:16 PM   #8
Plain Old Member
The showers / tubs have a styrofoam base / support under them. Pretty much all of the RV types do. Go look at a new one at a surplus. Not crazy about them, but I've never had one break or crack yet.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-21-2014, 12:18 PM   #9
Plain Old Member
Never had one like that, but not suprised either. Gotta wonder about the thought process sometimes.
Old 07-21-2014, 12:20 PM   #10
NELA
Weezer's Avatar
Youroo, when I say "flex" I mean no more than 1/8", over the entire shower pan floor. There's no more flex at the drain than there is at the side walls. It flexes only where the weight of each foot is.
show, shower
