Old 11-19-2018, 08:14 AM   #1
Jeff6146's Avatar
White hose run out from underneath front of RV
Iíve got a white hose coming from underneath my RV in the front and it is steadily dripping water. Does anyone know what this is or what it goes to and have to stop it. There is a small lake under my RV but thereís no leaks in the RV or in the belly. Any help would be appreciated.
Jeff6146 is offline   Reply With Quote
Old 11-19-2018, 08:26 AM   #2
Denver To Yuma In 90 Days
Originally Posted by Jeff6146 View Post
I’ve got a white hose coming from underneath my RV in the front and it is steadily dripping water. Does anyone know what this is or what it goes to and have to stop it. There is a small lake under my RV but there’s no leaks in the RV or in the belly. Any help would be appreciated.
It's possible that your fresh water tank has filled up due to a bad check valve in your water pump.
The white hose is probably the overflow vent hose.
Turn off your city water and run off of your fresh water tank with the water pump.
JohnD10 is offline   Reply With Quote
Old 11-19-2018, 08:28 AM   #3
bedubya's Avatar
Make? Model? Year? Photos? New or used? (If used, it could be something the previous owner added.)
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
bedubya is offline   Reply With Quote
Old 11-19-2018, 08:28 AM   #4
Jeff6146's Avatar
Iím thinking itís a check valve also. Where would it be located.
Old 11-19-2018, 08:35 AM   #5
Flybob's Avatar
If you are connected to city water try the following.
Turn off city water
turn on any faucet until there is no flow then turn off
turn on water pump and let it run until it stops
open any faucet and let it run for 30 sec
shut off faucet and allow water pump to run until it stops
turn off water pump.
turn city water back on.
Drain FW tank
This should reseat the check valve in the water pump.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-19-2018, 08:39 AM   #6
Mr. Dan's Avatar
I’m thinking it’s a check valve also. Where would it be located.
If it's the check valve mentioned by JohnD10, it's probably INSIDE the water pump... but could be before or after the water pump. Do a Search for "Fresh water tank filling" or some such. There are mechanical procedures which sometimes overcome the situation.
EDIT: Slower typist... I see Bob included the procedure in post #5.
Next, please answer the questions in post #3 .
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 0
Old 11-19-2018, 08:44 AM   #7
If Flybob's idea doesn't work, then you can add a check valve inline in front or after your water pump.
You don't have to replace the pump.
I did mine earlier this year...took me five minutes and no tools to fix!
Not sure what trailer you have (is it a 5'ver or a TT)?
Mine is a 5'ver, so the water pump is right next to the water heater just inside the basement on the offdoor side.
ID:	191790   Click image for larger version
ID:	191791   Click image for larger version
Old 11-19-2018, 08:55 AM   #8
ben31's Avatar
This works every time. Easy, comparatively cheap, and more reliable fix to the fresh water tank fill problem, than replacing the pump. The best location is before the pump (on the receive side of the pump), vice the pressurized side.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 11-19-2018, 09:07 AM   #9
That is where I put mine.
One, it was much easier to do as I didn't have to remove the water pump to install it.
And two, it just made more sense to me to put it there!
I've caught a lot of grief here from the self proclaimed 'professionals' about that placement and have been given their phD descriptions of why it shouldn't be in front of the water pump.
But I keep reading more often from those who put the check valve AFTER the water pump are reporting low water pressure issues.
Mine has been flowing perfectly since March, 2018 when I did the fix.
Old 11-19-2018, 09:22 AM   #10
Couple more things to add... Are you using a water pressure regulator?
High water pressure can overcome a perfectly good working check valve in the pump.
Also, make sure you don't have your 12v water pump switch on while using city water.
The pump, working against the city water pressure, can open the check valve as well.
No need for the pump to be on when using city water.
Days Camped: '16=46 '17=30 '18=51 '19=36
