Old 07-03-2018, 11:18 AM   #1
WiFi Thermostat
I want to install a WiFi thermostat for my dual zone dometic AC units.
has anyone done this yet?
Duramaxjb is offline   Reply With Quote
Old 07-03-2018, 11:24 AM   #2
Not sure exactly what you have but dometic uses a different kind of thermostat that is connected to a control box in the AC unit. I'm sure someone else will chime in but I'm pretty confident you won't be able to do anything like that because a regular house thermostat won't work.
"The answer may not lie at the bottom of a bottle of wine, but you should at least check." ― Unknown
Mmcglynn264 is offline   Reply With Quote
Old 07-03-2018, 01:14 PM   #3
Head Rambler
As Mmcglynn said, if you have a newer Dometic unit then you have the one with the digital communications and therefore you can't just replace the thermostat with a household model.
You can replace it, but you also have to replace the control box in the A/C and run new thermostat cable, which is usually the hardest part, because of how it's ran in and around stuff in the walls and ceiling.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 07-03-2018, 01:26 PM   #4
This is true. I have the dometic that uses the digital comms.
I ran into the same issue in my home (Honeywell). Can't use a smart thermostat unless I pull both parts out.
Sent from my Moto G (5) Plus using Tapatalk
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 07-03-2018, 01:49 PM   #5
well, that is no fun! Thanks all.
Old 07-03-2018, 05:40 PM   #6
If you have the Dometic capacitive touch stat, they now have a bluetooth version that is directly compatible. Otherwise you may be out of luck.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
thermostat
