Old 08-31-2014, 08:29 AM   #1
jrobichaud's Avatar
Winterized the 365saq
I am planning to have my campground winterized my camper but wanted to know if there are any things I need to let them know about.
I am aware of...
Water filter bypass
Tank flush valves w low water valves
Rear kitchen sink
Rear bath toilet and sink
Front bath toilet, sink and shower
Kitchen sink
I've owned campers for 15+ years and have blown out the lines then filled with anitfreeze. Not sure how they approach it.
jrobichaud is offline   Reply With Quote
Old 08-31-2014, 08:37 AM   #2
W/Heater,O/S shower,Filter assy,black tank rinse assy,F/W tank! Youroo!!
Old 08-31-2014, 11:07 PM   #3
fishgolf365's Avatar
Washer connection in bedroom closet and hose connections front and back of RV.
fishgolf365 is offline   Reply With Quote
Old 09-02-2014, 11:22 AM   #4
Helmsey's Avatar
Dont forget the outside spray port on the door side of the camper. It's just tee'd off the cold water line that feeds the galley sink.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 09-02-2014, 12:06 PM   #5
golfmedik's Avatar
Drain and block off the water filter. There is a round, metal plate with a rubber seal available to block off the filter canister so you don't waste that extra antifreeze. Also remember to winterize the spray ports on both sides as Helmsey eluded to. The washer connection as well if yours has it.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 09-29-2014, 07:03 PM   #6
Any recommendations on how to get the anti freeze in the black tank flush lines. As I typed this I figured it out LOL. So I might as well share my thought. Take the spray nozzle of the spray port hose because its a hose thread, plug the spray hose in to spray port faucet, screw other end of hose into black flush connector and turn on spray port after it already has some AF in it. TADA LOL
mrwoodmin is offline   Reply With Quote
365, 365saq, winter, winterize
