Old 09-22-2014, 04:58 PM   #1
Winterizing
Sure wish FR gave more information on the RV's they sell rather then the standard manuals. I love the docking station but wish there was at least a reference manual on the winterizing process. I understand the Hot water bypass that's an easy one. I assume you just hook a hose to the capped hose sticking out and stick it in the RV antifreeze to draw from with the pump?? Not sure what the other white shut off valve is , its just a hose that comes out with a white shut off and then the hose goes right back in. I assume its shutting of a water line??? Anyways just saying
mrwoodmin is offline   Reply With Quote
Old 09-23-2014, 06:16 AM   #2
golfmedik's Avatar
Yes the WH bypass has to be turned off and the other white valve you see there that comes out of the wall, then goes back in, yes the valve has to be turned in order for the pump to pull in the antifreeze.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 09-25-2014, 05:17 PM   #3
5erDriver's Avatar
Pull on the capped hose sticking out. It should come out to about 3 ft or so. Save trying to hook a hose to it. Drop right in the antifreeze.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 09-29-2014, 06:54 PM   #4
Thanks all for the replys, I'm good to go now. Happy Camping. Only 2 weeks left for us here in Vermont. Oct 12th is closing.
Old 09-29-2014, 06:58 PM   #5
davel1971's Avatar
bummer, that's way to early to quit. Everything is open here (Delaware) till Oct 31, a few till mid or end of Nov.
David & Lynn
Old 09-29-2014, 07:05 PM   #6
I agree Dave, I hate shut down, its a long wait for spring.
Old 09-29-2014, 07:13 PM   #7
mark0224's Avatar
Got to winterize soon hating the thought of doing it, want more summer never seems to last long enough.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
winter, winterize
