Old 03-31-2012, 11:25 PM   #11
caper's Avatar
f1100turbo it was not the fact you asked about the 110volts but bush saying to use a welder or dryer outlet that has me concerned.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-31-2012, 11:31 PM   #12
TURBS's Avatar
yeah explain that to the wife right !
well lucky enough for him if it was the case the camper connection and the dryer/welder connections are different . he couldn't have done it .
dryer has 4 prongs
welders prongs angle wrong way
rv 30 amp
Old 03-31-2012, 11:42 PM   #13
Drinkin beer on the beach
Rod Johnson's Avatar
Yep, all those electrical engineers tried to foolproof plugging things into the wrong place.
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 03-31-2012, 11:50 PM   #14
caper's Avatar
I know they are all different. That does not mean that a cord could not be made up to plug a 30 amp 110 volt cord into a 220 volt welding outlet. I myself would not do it but a person not knowing the voltage difference might.
Terry and Janet
2007 Ford F150
Old 04-02-2012, 11:07 AM   #15
rracer5's Avatar
I hope he was just confused and meant that a 110v 15a typical wall outlet in the garage type outlet is "not enough". Even a 20a circuit will only run the 13.5k a/c and that's about it. And, that depends on the guage, and length of the extension cord (if any).
Oh, and lets not forget that if the "home" shore power is GFCI protected, and you plug the trailer (which is also GFCI protected) in to it, one of them (usually the shore circuit) will trip at the slightest variation in current. May not happen right away, or may not happen at all but, is highly possible eventually. I had this happen to me twice at two different locations (a friends GFCI protected garage circuit and my own home's GFCI garage circuit). He's an electrician and told me GFCI,s "don't like each other" when hooked to each other.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
air, air conditioner
