Old 03-31-2012, 05:43 PM   #1
1st trailer ever- 1st use and a/c wont turn on
have wildcat 29 bhs extra light testing stuff out trying things and we turn on the a c blows hard and fast then stops and wont turn on again. any advice
cherylita is offline   Reply With Quote
Old 03-31-2012, 07:51 PM   #2
Drinkin beer on the beach
Rod Johnson's Avatar
Were you on shore power, or was the generator running?
Did any circuit breakers trip?
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 03-31-2012, 08:37 PM   #3
plugged into our garage
Old 03-31-2012, 08:53 PM   #4
bush's Avatar
pluged into outlet 110v/20a or a plug 30 or 50 amp for a dryer or welder? 110 is not enough power for most AC units
2011 puma unleashed 298fqu toyhauler.
hauling a 2012 polaris RZRS
pulled by a 2006 chevy 3500 drw 4x4 duramax lbz
bush is offline   Reply With Quote
Old 03-31-2012, 09:11 PM   #5
bikendan's Avatar
if you have a 15k a/c, your home outlet may not be enough. or your extension cord may not be enough.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-31-2012, 09:14 PM   #6
Iggy's Avatar
Reset your 15 amp circuit breaker.
The AC needs a minimum of 20 AMPs
Iggy is online now   Reply With Quote
Old 03-31-2012, 10:18 PM   #7
TURBS's Avatar
What are you talking about? 110 not enough?
Old 03-31-2012, 10:29 PM   #8
caper's Avatar
Do not I repeat do not plug the trailer into a welding to dryer outlet. They both are 220 volt. You need a 20 or 30 amp 110 volt outlet.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-31-2012, 10:29 PM   #9
And that welder or dryer plug is most likely 220. IF you could get your trailer plugged into that somehow, the AC would be the least of your problems...
Old 03-31-2012, 11:15 PM   #10
TURBS's Avatar
oh I know 220 is a problem I am trying to figure out why he said 110 wasn't enough !
a 13.5 k a/c unit draws somewhere in the neighbor hood of around 12-16 amps
a 15k takes about 23 to start and about 18 to run .
air, air conditioner
