Old 02-25-2014, 09:49 PM   #11
Congrats.
We also have a 327CK that we got in December. We have had it out once but are itching to go somewhere else soon!
I am interested in hearing how you like the washer and dryer. Ours is prepped for it and we have considered getting a washer and dryer at a later date
Jeff in NC is offline   Reply With Quote
Old 02-26-2014, 01:37 PM   #12
mlhawke's Avatar
I have the Wildcat 312BHX - 2013 and it was not ready made for the W/D hook ups. So I removed the two lower bunks (no kids) and had my dealer install the hook ups and Splendide combo unit. I love not having to go to the laundry in camp grounds. I have only used it a few times but already know I wouldn’t be without it. There are a few tip sites on how to use the combo unit. Read a few of them. Biggest thing I have found is it has very long cycles and you have to do smaller loads. Things will wrinkle if you over pack it. Also read about vented or non-vented. I selected vented so as to save on water, yes it uses water to dry the clothes J. I will be retiring at the end of this year and I know that it will get a real workout then. Happy Camping!!
The Hawke's have landed!
mlhawke is offline   Reply With Quote
Old 03-06-2014, 08:35 AM   #13
Originally Posted by Wildcat Chris View Post
The washer/dryer prep setup does NOT require an installation with the combo W/D unit facing into the closet area (first time I've ever heard of this kind of orientation!). The combo unit we built for is based on the popular Splendide washer/dryer -- I do not know the model number offhand. I'll get more info ASAP!
Chris,
Any further info on the washer/dryer setup
texfran is offline   Reply With Quote
Old 03-11-2014, 01:16 AM   #14
JAYCO Representative
Wildcat Chris's Avatar
Originally Posted by texfran View Post
Chris,
The Splendide WD 2100XC is the model which the space is designed for:
NEW Splendide 2100XC (WD2100XC) washer-dryer
Built-tough for RV and Marine use, the NEW 2100XC is Splendide's quietest, most durable and most convenient washer-dryer yet. Combining an entirely new drum and motor system with Splendide's flagship 2-in-1 design, the 2100XC is able to wash bigger loads than many stackable laundry sets, yet still saves valuable space, weight and resources.
Made specifically for use in mobile environments, yet elegantly suited in any high-end condo or loft, the Splendide 2100XC features easy-to-use controls, silent, brushless motor technology, added stability control and class-leading washing and drying performance.
Compare the 2100XC to other compact laundry centers and you'll see. With extra load capacity, a super-fast 1200 rpm high spin, modern Italian styling and more, the Splendide 2100XC makes a powerful and reliable laundry companion - on the road, at sea, or even in your uptown apartment.
Wildcat Chris is offline   Reply With Quote
cat
