Old 10-07-2013, 06:37 PM   #1
davec's Avatar
2 rear slide question
I just took position of a 2014 293REX 5th wheel last Sunday and finished taking the box of information and putting it in order. I found no information on the slides. I'm pretty sure the bedroom slide is a Lippert (by the sound) but understand the two rear slides may be cable driven and that's all I know. I want to get as much info as possible incase I run into a "slide malfunction" as I have been through that with my 2013 Crossroads Cruiser Air.
davec is offline   Reply With Quote
Old 10-07-2013, 07:15 PM   #2
Dave_Monica's Avatar
In your other post, you mentioned the ratcheting sound of the 2 rear slides when fully deployed/retracted which would indicate that they're electric operated with clutches. The pictures on-line show the bedroom wardrobe slide is a Schwintek drive.
If you look under the rear slides you should find a input shaft off the drive gearbox to fit a rachet on to operate them manually.
Lots of info on Lippert's site on the Schwintek slide drive.
Dave
Old 10-08-2013, 07:15 AM   #3
davec's Avatar
Many thanks. I got the info and will be adding it along with the other manuals.
Dave, Ana, and Knox
2015 Silverado 2500HD
6.6L Duramax Diesel
2014 Wildcat 293REX
slide
