Old 03-19-2018, 09:30 AM   #1
2011Wildcat 5th wheel 302RLS
There is a window above the dinette in our 2011Wildcat 5th wheel that light comes through in morning waking us up a daybreak. Does anyone else have this problem and if so, what did you do to alleviate the problem...details please....Click image for larger version
jbranontn is offline   Reply With Quote
Old 03-19-2018, 09:32 AM   #2
ManlyMan's Avatar
Go to the hardware store and buy some reflectix. Cut it to size and cover the window with it.
You must be light sleepers.
ManlyMan is offline   Reply With Quote
Old 03-19-2018, 09:34 AM   #3
Freedom2016's Avatar
Do not have the problem in our Wildcat. May I suggest applying some window film avail at an auto shop or home improvement store. Happy camping.
Freedom2016 is offline   Reply With Quote
Old 03-19-2018, 04:24 PM   #4
cavie's Avatar
a curtain valance come to mind.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-20-2018, 01:53 PM   #5
oldsmasma's Avatar
We had something similar in a previous trailer. I am a light sleeper. As cavie suggested I made a curtain valance using a pretty tea towel, a light curtain rod and a couple of command hooks.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
oldsmasma is offline   Reply With Quote
Old 03-20-2018, 03:20 PM   #6
We have the same window. We wish when we ordered the 5th have it deleted. Interferes with the slide topper. Also had it it tinted real dark to eliminate some of the light.
Portagie1968 is offline   Reply With Quote
Old 03-20-2018, 03:27 PM   #7
Looking at wimdow tinting it
Sent from my SM-G930V using Forest River Forums mobile app
Old 03-20-2018, 05:44 PM   #8
Window
For tint try the Limo static cling. Easy to remove if you need to and easy to install in multiple layers as needes. Recomended by all Vampires.
pdqparalegal1 is offline   Reply With Quote
Old 03-21-2018, 10:19 AM   #9
DouglasReid's Avatar
We have the exact same window over the dinette. Our bed is in the front though so with the door closed there is no light interfering with our sleep
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 03-21-2018, 10:30 AM   #10
Problem is with kids or whomever is sleeping on the foldout couch. We got cover for the door window
Old 03-21-2018, 12:17 PM   #11
It will look tacky but you can always tape some tinfoil over the window. NO light will get in.
I did that years ago when I was working nights and sleeping days.
Old 03-21-2018, 12:30 PM   #12
5er_tom's Avatar
Tin foil??? Have not seen that in years
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is offline   Reply With Quote
Old 03-21-2018, 01:09 PM   #13
Maybe not, but it is not because it does not work. It has three wonderful qualities:
FAST
EASY
CHEAP
and let me add the best:
EFFECTIVE
2011, 5th wheel, cat, wheel, wildcat
