Old 06-07-2015, 11:18 AM   #1
2013 293 Rex
Just wondering if anyone knows if there is a way to swap the order in which the living area slides open. I would like to make the slide opposite side of kitchen open first instead of the on slide same side of kitchen opening first.
Mbeld74 is offline   Reply With Quote
Old 06-08-2015, 04:19 PM   #2
I have a 2015 Wildcat 327ck with three slides and each one has a switch to go out and in. I can let then in and out in any order.
whj77372 is offline   Reply With Quote
Old 06-08-2015, 07:38 PM   #3
Thank you for the info. I have 3 slides also. But one switch operates two of the slides. Once one slide is out the other slide then moves out. I would like to switch the order in which the slides operate.
Old 06-08-2015, 09:13 PM   #4
Well, I would guess it can be done (by switching some wires) and suggest you ask your RV dealer or a good electrician. Maybe you can add another switch so they both have their own. It may also depend on how many motors move the slides.
My 2014 also has separate switches.
GypsiesAtHeart2016 is offline   Reply With Quote
