Old 07-31-2017, 03:26 PM   #1
28 sgx
Our shower drain opening is above the shower floor. Is this engineering screw up?Click image for larger version
MichaelW is offline   Reply With Quote
Old 07-31-2017, 03:34 PM   #2
mine looks like a normal shower floor pan and drains perfectly. love the larger shower!
A picture or better description would help.
dmac1951 is offline   Reply With Quote
Old 07-31-2017, 03:53 PM   #3
Shower
Here's the picture
Old 08-01-2017, 02:03 PM   #4
bsmall's Avatar
Well that's rather weird. Not very productive to drain off water from the floor pan.
Wonder if you take it apart see how it's installed and if you can modify the drain to be level with the pan.
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 08-01-2017, 02:06 PM   #5
28 sgx
I took the strainer off the housing is still Above the floor
Old 08-02-2017, 05:53 PM   #6
That was one of the things on our hit list of our unit.
The service department replumbed the drain and took a bit out of the length of the down pipe. It's lower but not flush.
Parrott_head is offline   Reply With Quote
Old 08-03-2017, 11:38 PM   #7
cavie's Avatar
It is installed correctly except it should be in a recess in the floor.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
