Old 02-22-2018, 06:54 PM   #1
28sgx wildcat
The switches for the water pump and hot water heaters. Why donít the light up when they are on
MichaelW is offline   Reply With Quote
Old 02-23-2018, 10:43 AM   #2
SeaDog's Avatar
the water heater will only light while the ign part of start up is in progress once running it goes out. As for your pump I'm not sure my switch doesn't light for the pump
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-23-2018, 11:00 AM   #3
You are right
Old 02-23-2018, 02:12 PM   #4
Dennis and Julie's Avatar
Ours don't light up either.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 02-23-2018, 02:32 PM   #5
Mr. Dan's Avatar
The water pump switch on my Wildcat 295RSX has always lit up when the switch is on.
The water heater switch for propane DID NOT light up - burned up some propane while sitting in the trailer shed because we didn't notice the switch had been bumped. I knew the switch had a bulb in it. All I needed to do was get it to light up. I pulled the switch and found it had 3 terminals -- 1 was the pos. input to the switch & appliance. 2 was neg. output from the switch to the heater control board. 3 was neg. output for the bulb in the switch. It had no ground (neg.) wire on it so I added one. Now when I flip the switch, its little light bulb comes on and stays on until I turn off the switch.
Don't confuse the light in this switch with the red fault light which stays on UNTIL the unit's burner lights then goes off. (Of course, it stays on if the heater doesn't light.)
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 02-23-2018, 02:34 PM   #6
Mr. Dan's Avatar
SDog, looks like you're talking about the heater's fault light, not the ON/OFF switch.
Old 02-23-2018, 09:07 PM   #7
onetonford's Avatar
The water heater switch if it is a surburban is only for ign or fault others are different. If the water pump one doesn't work possibly the wire is hooked up for the light is connected wrong or not hooked up at all or light is bad. Mine has always worked.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
cat, wildcat
