Old 02-25-2016, 10:27 PM   #1
312Bhx tv
Ok talking about the television. It is plugged in behind the panel I cannot see a way to access where it is plugged in.
Reason I am wanting to is I want to connect it to a inverter so I can watch the tv off the battery vs having to run a generator or having shore power.
Timna is offline   Reply With Quote
Old 02-26-2016, 04:19 PM   #2
RSchleder's Avatar
Either the panel can be removed (screws/clips) or you should be able to reach around the panel or go at it from the other side of the wall it's plugged into. Since I don't have this model RV I can't give specifics on accomplishing the task of unplugging the tv.
If all else fails, call your dealers service dept.
Good luck!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 02-26-2016, 10:41 PM   #3
Your in luck! I have a brand new 312BHX. If your talking about the main TV I spent all day in that compartment today. Remove the flexible panel near the utilities. 4 screws on the edge and once open you will see about 6 more on the inside. Remove the cream colored panel in the pass through about 6 screws also. This is the panel facing the interior of the trailer. You can now access pretty much everything. I was installing my surge protection today so spent lots of time crammed up in there! fighting that 50 amp. cord. You should see where all the wires run up the wall.
I took the time to straighten out some wires and redo the converter ground as well. You might want to check the furnace ducts while in there. I found several crimped, holes in some and one barely even connected. Brand new trailer! Every brand I have owned has been this way. I spend time going through it now to avoid a **** show while on the road.
2016 Wildcat 312BHX
2015 Silverado 3500HD
sugarjohnson is offline   Reply With Quote
312bhx
