Old 12-27-2014, 11:54 PM   #1
Greenshield's Avatar
344QB 2013 low point drain
I can't find thelow point drain on my 344QB. Anyone know where it is?
2013 Ford F-350, FX4 ,Long Bed, 6.7 Diesel, 11500# GVW package, camper package, plow package, Electronic locking 3.73 rear end.
Husky 16K slider hitch.
New Trailer 2013 Wildcat 344QB Touring Edition with angled master bed.
Greenshield is offline   Reply With Quote
Old 12-28-2014, 08:56 AM   #2
Mine is right next to the sewage drain tube. Only one drain location.
5'er: 2013 Wildcat 344QB
TV: 2011 GMC 2500HD Duramax
2014 camp days planned: 58
Jack77 is offline   Reply With Quote
Old 12-28-2014, 09:01 AM   #3
I thought that was just for the fresh water tank.
Old 12-29-2014, 08:44 AM   #4
The low point drain is the same as the fresh water drain. It's the only location to drain your fresh water tanks from.
2014 days camped: 73
Old 12-29-2014, 01:51 PM   #5
The low point drain isn't usually used to drain the fresh water tank, but to drain the water lines in the unit. I don't know about the 344QB specifically, but on the 312's there are hot and cold low point drains between the main door and the pass through storage door, outside of the frame rails, up behind the skirting. You may need to crawl under and look up between the frame and skirting, as they do not hang down low enough to see them easily just by looking underneath, unlike the single tank drain, which is quite easy to see...
pbryan is offline   Reply With Quote
Old 12-30-2014, 08:20 AM   #6
jumbo131's Avatar
On the 344QB the low point drain lines are by the front entry door steps. In between the space between the frame and the outer skin they're blue and red. The blue one in the front on the opposite side by itself is for the fresh water tank.
2011 F350 Dually 13,300 GVWR 3.73 ratio
2013 WildCat 344QB with outside kitchen
jumbo131 is offline   Reply With Quote
Old 12-30-2014, 10:22 AM   #7
jevanb's Avatar
our 344QB did not come with a system low point drain, just a drain for the fresh tank, I have had the lower belly covers off and it is no where to be had
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 12-30-2014, 08:51 PM   #8
jonrjen's Avatar
I didn't think that our 353LS had any low water drain points either. All I ever saw was the drain for the fresh water tank. Then when our 353LS was in the shop up in Elkhart having some warranty work done, one items was to replace the bottom cover under the trailer. Low and behold all of a sudden I had low water drains for both the hot and cold. It would appear that along the production line they stuffed the low water drain points up under the liner under the fifth wheel. I would recommend pulling a few screws and look under the liner under the frame. Mine come out very close to the grey and black water drain point.
Good luck,
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
2013, drain
