Old 04-24-2014, 08:23 PM   #1
50amp plug at a 30amp receptacle
Thanks to everyone for answering my previous question....but I've got another one if you could help. What do I have to be careful of when I'm using a 30amp plug only when a 50 isn't available. Can I run one ac? Could I damage anything electrical? Thanks in advance!
Dirk
BeachAddict is offline   Reply With Quote
Old 04-24-2014, 08:34 PM   #2
You can use up to (30Amp). You can run (1)AC. You will prob.trip the (Post 30) if you try to use more. No harm. Youroo!!
Old 04-24-2014, 08:39 PM   #3
davel1971's Avatar
you "should" trip the breaker on the pole before any damage is done. One AC would be fine, just not to many electrical appliances at once, such as water heater, coffee pot, micro, toaster, hair dryer, etc. Those add up fast.
David & Lynn
Old 04-24-2014, 08:59 PM   #4
Road-King's Avatar
I have a related question. Those 30 amp to 50 amp dog-bones, I assume they are wired to give juice to both legs, for a total of up to 30 amps? I have one those cheaters that would give me 30 amps to one leg and 15 amps to the other, if available at the post.
The reason I ask is I installed a surge guard in my new 50 amp 5er and I noticed that both A/C's were on the same leg...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 04-24-2014, 09:21 PM   #5
dan-nickie's Avatar
Dirk, you should drop in on your other thread and let people know that you have been reading their posts.
They will be more likely to answer your future questions.
Happy Camping
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 04-24-2014, 09:32 PM   #6
Anacortesians
If the CG post is 30A, that's probably all that's available, whether from a pair of residential 15 A sockets or an RV 30A socket. I wouldn't assume that you could get any more current by using the residential outlets + the 30A RV outlet. I think you'd blow the breaker on the post.
There are a lot of CGs that haven't moved into the 50-amp world yet.
Frank and Eileen
No longer RVers or FR owners
Old 04-30-2014, 09:27 AM   #7
Road-King's Avatar
Thanks F and E, I do understand that I can only get what amps the post has. Those cheaters are not magic.
Still my question is does those 30 amp male to 50 amp female, dog bones, give juice to both legs? I assume they do.
Also is it normal in a 50 amp setup for both A/C's to be on the same leg?
Russ & Kim
2014 Alpine 3600RS
Old 04-30-2014, 09:40 AM   #8
wmtire's Avatar
Yes, the dogbone will share/jump (see chart below) the 120 volt 30 amps across both the L1 and L2 lines of the 50(x2) amp RV connection. This is why you must be absolutely certain when using the adapter, to make sure you don't plug into a 240 volt 30 amp outlet..............which does happen. If you plug into a 240 volt 30 amp outlet, it will send 240 volts down both legs (L1 and L2) and fry some stuff.
ALWAYS make sure the 30 amp you are plugging into is 120 volts ONLY.
I don't think it is normal for both AC's to be on the same line/leg. Usually from what I have seen, they are on separate legs/lines, but maybe others with 50 amp RV's will chime in.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
