Old 04-29-2016, 10:22 AM   #1
5th Wheel Front Jack Setup
Been camping for many years, but this is first 5th wheel. Took rig for the first trip last weekend and thought i had everything figured out. I put wood blocks under the front jacks, dropped them down, pinned them and raised until i could get my truck out. The problem was when i went to hook back up; the jacks would not raise high enough to release the wood blocks. I tried raising the airbags on my truck and that did not help. We were set up on hard gravel so the front end did not sink. The only thing i could figure out was that the extra weight due to my gray and black tanks being over half full was enough to keep the pressure on the blocks. Needless to say, after an hour of scraping gravel, beating on the blocks with a hammer, chopping the blocks away with a hatchet and draining some of the grey water on the ground (i know, illegal), i was able to get one block removed and ended up driving off the other one (luckily with no damage to the jack). In the future, should i not drop the front jacks down so far so i have room to adjust up and down?
FFRich is offline   Reply With Quote
Old 04-29-2016, 10:43 AM   #2
Oaklevel's Avatar
I have had two fifth wheels I lower the legs part way put the pins in, then run the motor down the remaining way till they are on the ground/ blocks, then lift. That gives you room to lift and lower the front for leveling as well.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 04-29-2016, 10:53 AM   #3
B and B's Avatar
X2 leave some wiggle room for soft soil
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-29-2016, 10:54 AM   #4
Head Rambler
I do as Oaklevel said. Run the landing gear down a ways and then lower the extension tubes onto blocks or the pad (depending on the pad, I'll sit them right on it) and then lower the landing gear to clear the hitch and drive from under it. That way you can lower the front a little if you need to and it also gives you a little room to raise the gear higher if needed.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 04-29-2016, 11:01 AM   #5
leefl's Avatar
Agreed. I always adjust the legs to leave the feet about 3 inches above the ground or blocks, and then use the power to lower them onto the ground and lift off the hitch.
That way there's plenty of adjustment both ways. Can lift plenty above the hitch height if needed; and there's always plenty of clearance off the ground when hitching back up, after fully retracting with power, before sliding the leg extensions back up and pinning
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 04-29-2016, 11:01 AM   #6
Thanks all!! It appears i am on the same page for thinking that way. Guess it just did not cross my mind since i was on a hard surface. Live and learn i guess
Old 04-29-2016, 11:01 AM   #7
clr
I have had 3 5th wheels now the current one has hydro front landing gear, so it is another beast. But I always would place a plank under the front landing gear and then lower the landing tube all the way to the ground and then lift and pin the gear in the first hole up from that. By the time you lower to the ground again and then lift the 5th wheel off of the truck you have plenty of wiggle room. With this method I never had any problem with not being able to lift the 5th wheel high enough to get the board out.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is online now   Reply With Quote
Old 04-29-2016, 11:07 AM   #8
Pickin' & Campin'
I simply don't ever run the electric part of my front jacks to the clear up position.
I always leave them down an inch or so.
Leaves plenty of room to get blocks out in a jam and are retracted plenty high enough they don't ever come close to scraping.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-29-2016, 11:35 AM   #9
When that happens I use my bottle jack to lift frame until I can pull block. Then I can pull pin and store the leg for travel.
Harkerr is offline   Reply With Quote
Old 04-29-2016, 01:51 PM   #10
Another tip I wish I had known about on my first couple of trips is to not lower the rear stabilizers until the trailer is level. If you lower the rear stabilizers first, you'll be asking the front jacks to lift the entire weight of the trailer, which they aren't designed to do. Cost me a new motor and a lot of aggravation.
DrLewie is offline   Reply With Quote
5th wheel, wheel
